warning bell volume adjustment
Old Jan 16, 2011 | 06:48 PM
rkirkley's Avatar
rkirkley
3rd Gear
Default warning bell volume adjustment
My '06 has a warning bell that's obnoxiously loud...
any way to turn that sucker down?
Thanks!
Old Jan 16, 2011 | 07:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NEGATIVE Ghost Rider,,, Its a function of the Instrument Cluster. You can, remove the cluster and put tape over the speaker output opening.
BC
Old Jan 16, 2011 | 08:07 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Or... You could determine what is causing the chime, and either fix what's wrong, or get someone with HP tuners to turn off the reporting for that error for you (it'll cost an HP tuners license, $99 plus whatever they charge).
Old Jan 17, 2011 | 06:07 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
FWIW, the chime on our 2009 is much quieter than the chime was on our identical 2006.
Nav radio, set on quiet setting.
Not sure if that's a deliberate change in something, or just car-to-car variation.
Old Jan 17, 2011 | 06:46 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
When I swapped my 2005 radio for a 2010 radio, all of my chimes became significantly quieter, and also seem to have a different note.
Old Jan 17, 2011 | 08:31 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
The radio is used to adjust the chimes volume level.
There are 2 settings, loud and louder.
With the ignition on and the radio power off, press and hold button #6, the volume level will change from normal to loud and "loud' will appear in the radio's display.
Repeat the process to change to normal and "normal" will be displayed.
This is in the Owner's Manual for the radio with CD (with or without Bose) but I'm not sure what's in the Nav's Manual.
Old Jan 17, 2011 | 11:35 PM
Fuego's Avatar
Fuego
I have no bell sound at all! I remeber watching a vid of Jay Leno talking about the nice bell sound when he opens his Vettes door. I always wondered why I have never heard it?
Old Jan 17, 2011 | 11:46 PM
sevinn's Avatar
sevinn
Do you have an aftermarket radio?
Old Jan 17, 2011 | 11:53 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Try leaving your lights on and getting out?
When the OP was talking chime, I thought he meant the fault chime like when you get a "service charging system" message on the DIC.
That is ear splitting loud, 20x louder than the "lights are on" chime. It drowns out the radio or any conversation and is extremely annoying. I had to turn off the charging system error reporting when I went to an underdrive pulley. I've not had any charging issues in nearly 3 years now.
To warning bell volume adjustment
