Transmission Problems
Old Jan 26, 2011 | 09:59 PM
74c395c4's Avatar
74c395c4
Default Transmission Problems
My transmission is shot at 30K from a 2005 Z51 6 speed. Any thoughts regarding rebuilding it or replacing with a used trans? Thanks
Old Jan 26, 2011 | 11:12 PM
Silver Bullet C6's Avatar
Silver Bullet C6
St. Jude Donor '10-'11-'12
Manual or auto 6 speed?
Old Jan 27, 2011 | 07:41 AM
CMY SIX's Avatar
CMY SIX
2005 auto would be a 4 speed wouldn't it? if it's manual or an auto why would it be shot at 30.000 miles? clutch?
Old Jan 27, 2011 | 07:44 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Please give a better description of the problem and what your driving conditions were for the 30k miles overall.
Old Jan 27, 2011 | 08:56 AM
TJ@RPMtransmissions's Avatar
0TJ@RPMtransmissions
Former Vendor
I would shy away from a used transmission as you have no idea what you are getting. Even if they give a warranty on the used unit, you still would have to pay labor again if it was bad within the warranty period.
Rebuilding the transmission is okay but many times can cost as much as a good upgraded transmission.
Let me know if you have any questions and I would be glad to assist you as much as possible.
Thanks,
T.J.
Old Jan 28, 2011 | 03:35 PM
74c395c4's Avatar
74c395c4
The Transmission is a 6 speed manual. It has been driven easy. Transmission shop recommended by local corvette club says rebuilding will be from 1800 to 2800. This does not include cost to remove it from car.
Old Jan 28, 2011 | 06:50 PM
m_LeDez's Avatar
m_LeDez
From: Houston, Tx.....'05 Corvette M6 LS3 Magnuson Heartbeat
PM sent.....
Old Jan 28, 2011 | 08:44 PM
dgrant3830's Avatar
dgrant3830
What's wrong with it?
Old Jan 29, 2011 | 09:22 PM
74c395c4's Avatar
74c395c4
Really bad noise when driving. It is a continuous loud squeal that subsides a bit when you let off the gas. It occurs in all gears with the exception of 4th. It's mostly quiet in that gear.
Old Jan 29, 2011 | 11:43 PM
Daredevil95's Avatar
Daredevil95
The cheapest I could find.....not a bad deal.
http://compare.ebay.com/like/3803113...fd96bc5&itemid
Old Jan 30, 2011 | 09:35 AM
dgrant3830's Avatar
dgrant3830
Get it off the ground onto jacks. Have someone start it, get it in gear, you under it and start listening. Insure its coming from the transmission. Next please check your fluids in the transmission and differential.
Old Jan 30, 2011 | 11:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds more like a torque tube noise. I like dgrant3830 Idea. Pin point the noise and go from there. Drain the tranny ATF and examine the fluid.
If it shifts good, theres a chance its something other than the tranny. Any chance of making a video of the noise and posting it?
BC
To Transmission Problems
