Mast Black Label heads - Share your experience
Old Jan 30, 2011 | 07:24 PM
ktoonsez's Avatar
ktoonsez
Default Mast Black Label heads - Share your experience
Figured I would start a new thread for this:
Car is an LS3, thinking about doing a head swap for Mast Black Label Med. Bore. Anybody done this swap on LS3 or similar bore/ci engine? They are saying 50-75 HP with the swap with my current setup.
Old Jan 30, 2011 | 09:42 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Did you see the comparison test in Hot Rod magazine last month? These heads seemed to do well on the 408ci with a big cam.
Are you also changing the cam?
Old Jan 30, 2011 | 10:04 PM
ktoonsez's Avatar
ktoonsez
Yes I did see the article and it appeared to do the best out of all of them, of course I wished it would have been my LS3 as the test. The heads might be a stepping stone to a bigger cam (since I would get more PTV clearance with aftermarket) if I don't get a good amount of added horsepower with the heads alone. Here are the current mods:
227/231 .613/.617 115+3 LSA cam
Headers
CAI
3.42 gears
Old Jan 31, 2011 | 12:55 PM
Mez's Avatar
Mez
The article showed all the heads were tested incredibly close despite a wide range of port and CFM.
The Mast did have the most peak torque but only a little. The ProComp posted the highest peak hp with the smallest ports and lower CFM.
I made a bar chart comparing the different heads in this test because I had difficulty figuring out the results. I still don't understand why they all delivered similar hp and tq. Here is that thread. http://forums.corvetteforum.com/c6-t...head-test.html
I wish they had simply used a LS3 with a medium size cam like most of forum members use.
The MAST was the only square port head in the test. The rest were cathedral ports because the 408ci bore. They did not test a stock L92 head.
If the MAST does deliver a 50hp on a stock LS3 heads+cam, I would like to see it.
Old Jan 31, 2011 | 05:36 PM
ktoonsez's Avatar
ktoonsez
Wish someone out there has tried it
Old Feb 1, 2011 | 06:25 PM
ktoonsez's Avatar
ktoonsez
bump
Old Feb 3, 2011 | 08:02 PM
ktoonsez's Avatar
ktoonsez
bump, someone out there has had to put some of these on there LS3
Old Feb 5, 2011 | 12:42 PM
ktoonsez's Avatar
ktoonsez
ttt
Old Feb 8, 2011 | 11:23 PM
ktoonsez's Avatar
ktoonsez
bump again
Old Feb 10, 2011 | 10:47 PM
ktoonsez's Avatar
ktoonsez
ttt
Old Feb 10, 2011 | 11:05 PM
Kingsize's Avatar
Kingsize
Reason they all showed similar results although they are significantly different in design and flow capability, is because we have gotten to the point where the intake is the restriction and the heads can only make due with the amount of flow that they receive. Had each engine gotten it's own sheet metal intake, the results would be very different.
A radically different intake design is sorely needed if these high end LS heads are to meet their potential. The FAST 102 is not enough.
Old Feb 11, 2011 | 05:51 PM
ktoonsez's Avatar
ktoonsez
Good point there, I guess what is nice is that there is more room to grow the cam durations due to the change in valve angle creating more PTV clearance. Still looking for someone that has actually done this. Anyone??
Old Feb 21, 2011 | 01:20 PM
ktoonsez's Avatar
ktoonsez
bump
Old Feb 24, 2011 | 08:41 PM
ktoonsez's Avatar
ktoonsez
ttt
Old Feb 27, 2011 | 12:31 AM
ktoonsez's Avatar
ktoonsez
bump
Old Mar 6, 2011 | 04:51 PM
ktoonsez's Avatar
ktoonsez
ttt
Old Mar 8, 2011 | 08:15 PM
ktoonsez's Avatar
ktoonsez
Evening bump
Old Apr 15, 2011 | 11:05 AM
ktoonsez's Avatar
ktoonsez
ttt
Old Apr 21, 2011 | 11:39 PM
ktoonsez's Avatar
ktoonsez
bump
To Mast Black Label heads - Share your experience
