Headlight Lens disassembly
Old Jan 30, 2011 | 10:04 PM
AtsZR1's Avatar
AtsZR1
Default Headlight Lens disassembly
I have a set of c6 headlights that need to come apart to clean them out. I think that they were in a flood car. How do I get the lens off? What parts will I need? Thanks.
Old Jan 30, 2011 | 10:13 PM
RicK T's Avatar
RicK T
The lens is bonded to the housing with a mastic type material similar to windshield sealer. It IS NOT easy to take them apart. A few have been successful baking them to soften the sealer but it's a fine line between just enough heat and melting everything. Others say to use a Dremel type tool to cut the sealer.
Just for info, member RLSebring is kind of the headlight expert around here. Might contact him for advice. Also, EastCoast Performance offers a service where they will replace the lens. Here's the link:
http://forums.corvetteforum.com/c6-c...t-service.html
Good luck.
Old Jan 30, 2011 | 11:20 PM
veech's Avatar
veech
I just did this... it was easy as pie. 15 min @ 275* and just pry it apart. if you wait to long you might need to put it back in the oven to warm it up...
Old Feb 14, 2011 | 12:33 PM
Thudux's Avatar
Thudux
Awesome ..... what did you use to re-seal it? Same existing glue just re-heating?
Old Feb 14, 2011 | 09:19 PM
c6coop's Avatar
c6coop
Great info.
Old Feb 14, 2011 | 09:31 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
I heard 20 min @ 225. I need to do this, Just have not been brave enough. I have a spare set that I would like to modify and put new lenses on. RL was not too helpful on the details of removing the lense. I would think that you could just reheat to reseal the new lense?
Old Feb 15, 2011 | 01:14 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
I wasn't helpful? That's odd because I try to be.
Old Feb 16, 2011 | 08:13 PM
c6coop's Avatar
c6coop
If you do this, let us know how it goes. I would think the re-heat would help seal the lens.
Call me chicken coop.
To Headlight Lens disassembly
