Complete Fuel system for under 2k
Old Jan 31, 2011 | 08:09 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
Default Complete Fuel system for under 2k
Looking for a fuel system to support 750-800whp on e85.
Complete from tank to fuel rails,
I'd like it to have teflon lines, also, the lines fittings and components visible in the engine bay to be black, no multi red and blue colors
I like the twin pumps, especially the aeromotive 340's coming out. but might not be enough, and relying on two pumps reduces the reliability of the system.
Dont want to tap/cut holes in the fuel tank.
Dont want to hear the pump except for key on engine off
Dont want to rely on Hobbs switches
fuel pressure 60 base with vac/boost reference running ID1000's maybe the 1600's stock line utilized for return.
I know I pretty much just eliminated 99% of the kits out there, but there has to be something! show me what you got!
-Carl
Old Jan 31, 2011 | 08:25 PM
breecher_7's Avatar
breecher_7
-Carl
Pretty much eliminating everything... You can hear both the RSI and the Aeromotive systems while the car is running.... Your going to hear anything with an external pump most likely... Good luck....
Old Jan 31, 2011 | 08:27 PM
TrenAman's Avatar
TrenAman
-Carl
HOB 1000hp system setup is 2,100 +25 shipping.. it includes everything you need I would spend the extra $200 and get the 1300rwhp system.. actually I did lol
Old Jan 31, 2011 | 08:30 PM
carlrx7's Avatar
carlrx7
I saw that kit, and i still have my eye on it, BUT, i need to hear that pump, i know how loud it is from videos on youtube (ridiculous!), how quiet does it get with it being in tank and with the speed controller?
Old Jan 31, 2011 | 08:53 PM
TrenAman's Avatar
TrenAman
it is being isntalled in my car right now "with an A4 RPM Conversion".. if you can hold off a week or 2, I will make a vid for you..
Old Jan 31, 2011 | 09:08 PM
carlrx7's Avatar
carlrx7
If HOB can make a video I will order the kit now. I would be getting the eliminator as well.
Old Jan 31, 2011 | 09:57 PM
breecher_7's Avatar
breecher_7
This is the aeromotive kit I wa speaking of. I have it in my car, you can hear it plain as day while the car is running. So I guess you have to take that off your list.
Old Jan 31, 2011 | 10:02 PM
carlrx7's Avatar
carlrx7
do you have the speed controller?
Old Feb 1, 2011 | 09:53 AM
carlrx7's Avatar
carlrx7
H.o.b. Bump
Old Feb 1, 2011 | 10:22 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
All kits have to rely on some kind of a hobbs or boosta pump device to run them. The Aeromotive unit cannot be ran full powered all the time so their voltage limiting unit is needed, the twin tank units use a hobbs, as well as our secondary pump. If you were so concerned with a Hobbs switch failure, you could simply use two, somewhat like how an airplane would be set up, so there is always a back up.
Obviously I'm biased, but we could fill your HP needs, and not hear ANY fuel pump noise, while staying within your budget too, with a kit that is very well proven, if not the most proven set up out there.
Old Feb 1, 2011 | 11:37 AM
TrenAman's Avatar
TrenAman
PM vette.se I know from another thread he has the Eliminator installed
Old Feb 1, 2011 | 01:14 PM
breecher_7's Avatar
breecher_7
This is not always true. Alot of the guys running the RSI kits, including the one we ran, were running both pumps on at all times with no problems at all. Other then the power draw from two pumps, running them both all the time does not negativly effect anything.
Hobbs switches are pretty damn reliable though, ive never personally seen one go bad. Just make sure you have a good fuel pressure gauge and you pay attention to it.
Old Feb 1, 2011 | 03:07 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Yes and no, nothing against that set up, but running two pumps all the time heats the fuel a lot. We switched to Hobbs units because some of our customers in the warmer climates would actually boil the fuel in the tank after a long trip. That cant be good!
I have not had a Hobbs switch go bad either, but some are not comfortable with them.
To Complete Fuel system for under 2k
