Codes
Old Feb 3, 2011 | 09:43 AM
VNVETT's Avatar
VNVETT
Keeping my fingers crossed, I got up this morning and clerard the code and put four new wires in and started the enhine and let it heat up to operating temp..bout 210-220 and let ot idle the whole time. The light did not come on..knock on wood and the idle was smooth and steady at 950. I will let it cool dopwn for a couple of hours and try it again. Bob
Old Feb 3, 2011 | 10:45 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Hang in there Marine! Semper Fi! Let's hope this is still external for an easy fix.
Elmer
Old Feb 3, 2011 | 12:02 PM
VNVETT's Avatar
VNVETT
Thanks and semper fi to you too Elmer. Keep your fingers crossed.
Old Feb 3, 2011 | 12:25 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Also double check to make sure the low voltage wires on each coil and each injector are plugged in..since you had a cam put in, somebody's taken them out before, and sometimes they come loose. I had the low voltage plug on one coil come loose and got the p0300.
I also couldn't agree more with Bill to not take a cammed and tuned car to the dealer. Take it back to the shop that put in the cam if at all possible, or another reputable tuner shop. Oh, and with a cam, you should replace the springs at 20,000 miles or so.
Bill, I've also found the hand held scanners don't give the individual cylinder codes, just 0300.
Good luck!
Old Feb 3, 2011 | 12:51 PM
GARYFINN's Avatar
GARYFINN
From: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Originally Posted by eboggs_jkvl
Wait until night. Start the car in the garage to help keep it dark. Look in the engine compartment while the car is running. If you see the aurora borealis in there, that's your problem. If no spark show exists, then it's coil(s), or internal. Pray for light show.
Elmer
Old Feb 3, 2011 | 01:16 PM
VNVETT's Avatar
VNVETT
How do identify these low voltage wires. Can anyone post a pic?
Old Feb 3, 2011 | 01:18 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Its the smaller wires that plug into the coils and the fuel injectors. You cant miss them. Just push in the plugs to make sure they are clicked in.
Old Feb 3, 2011 | 01:22 PM
BT03mach-1's Avatar
BT03mach-1
i was going to say just check ALL the wires in that area. but it sounds like you may have already fixed it? or did the code come back?
Old Feb 3, 2011 | 01:41 PM
VNVETT's Avatar
VNVETT
Code can back
Old Feb 3, 2011 | 02:09 PM
VNVETT's Avatar
VNVETT
This car idles perfect and when I dropve down the road a few minutes ago it was smooth as glass with no skip or cutting out, had plenty of power and when I got back the idle was fine. Stupid question...Would a loose gas pap throw a 0300 type code?
VNVETT's Avatar
VNVETT
i mean gas cap..sorry
Old Feb 3, 2011 | 02:12 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
No.
A loose or faulty gas cap will cause the car to say "check gas cap" in the drivers info center under the tach and speedo.
Check for loose wires on the coils and injectors...
Old Feb 3, 2011 | 02:34 PM
  #33
VNVETT's Avatar
VNVETT
Thanks, will do
Old Feb 14, 2011 | 06:53 PM
  #34
VNVETT's Avatar
VNVETT
Default Codes
Just a quick update on my problem. I finally went out and bought a real code reader and when i checked the code it showed P0300, I then scrolled down to GM and it read codeP0030, which is the drivers side 02 sensor...upstream. Well I went to the dealer and bought the new 02 sensor and put it in. Then I erased the code and drove around. No light. I shut it of and cranked it up again and still no light. Put about 50 milesd on it and everything is fine. Thanks everyone for all your help and concern. This is what make this a great forum....people caring....semperfi everyone...VNVETT
