Just curious what are some of your best 60 foot times with 19" drag radials?
I think it has been beaten to dealth that a 18" tire is a better selection for traction but I have never seen any hard numbers on what can be done with a 19" tire. I have a 550rwhp auto car and would like to be able to pull a 1.70ish 60' but am not sure if thats a reasonable expectation from a 19" DR. Currently I have 19"x10"s on my car but am also considering going widebody if the traction would be significantly increased. In a perfect world I would like to have a 18x12 spyder wheel and run some kind of r compound tire. But spyder wheels are not made in a 18x12 and I dont think one can be widened without having some sort of serious spacer.
So post up any 60' times with either 19"x10"s or 19"x12"s.
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I run 345/30/19 with a Nitto NT05R and consistantly cut 1.58-1.63's. Here are a couple videos from last year. FWIW, my wife rips off 1.66-1.75's on the same tires so you should be fine.
1.58 is not to shabby. Thanks for the video the z was getting it done. Based on your results 19" drag radials have more potential than most think.
Most people who think a 19" drag radial can't cut a 60' are just speculating
In the Fbody days people thought a 15" DR was where it was at to run serious times, but one of the quickest NA cars ran on a 17" setup and was getting it done WELL into the single digits.
There is only a single 19" drag radial out at the moment.
I think once the MT 305/35/19 comes out more people will be running it since it'll fit in the stock C6 fenders. Right now only the 345 NT05R exists in 19" size.
