- Exhaust Modifications
Overview of popular modifications to customize your Corvette
Browse all: Engine and Powertrain
Exhaust Modifications for C6
If you want a little more performance as well and you don't need to worry about smog checks, then maybe some headers would be a better fit for you.
There also the NPP, or Z06 version of the dual mode exhaust systems. You would just need a control system to run it like NPP in a box and it can be quite and loud when you want it to be.
I took off my NPP and went with a full Z06 set up with modded mufflers so I can still pass smog. That with a tune was good for 20rwhp and around 15rwtq.
DJ
I tried multiple exhaust setups which all drone at 1700-1900 rpm. The Corsa is great without any drone which all the others have, I'm told.The best in my opinion is the setup I have now. I had a set of Z06 mufflers (with the muffler mod done) installed by FasterProms speed shop with the Mild to Wild switch by "Red Lion" vendor. I have long tube headers "WITH" the cats although they are hi-flo versions. Without cats your exhaust will smell horrible.
Now I have quiet and beast at the flip of a switch. My wife even approves.
Headers can run 1K-2K with a tune and install plus the mufflers will set you back another 600-800 with the install. A muffler shop will have to install these because the mufflers will be welded up to your over the axle pipes.
Jeff
Click my You-tube link in my signature for the sound wide open at the track.
Take your time, one day in the garage with jack stands and your done.
DJ
