Coated vs. Non-Coated Headers....
Old Feb 5, 2011 | 07:07 PM
bigred6906's Avatar
bigred6906
Default Coated vs. Non-Coated Headers....
On my 2003 Z06, I used Kooks non-coated headers. Looking to add headers to my 2010 GS. Should I go coated or not? Advantages and disadvantages of each? Lets get some knowledge from the CF wise men...
Old Feb 5, 2011 | 07:18 PM
timd38's Avatar
timd38
I would ask your header supplier.
Old Feb 5, 2011 | 08:13 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
I do not hear of many vette owners wrapping their headers, but I know an Evo owner and he can put his hand on his headers when car is at operation temp. I can't do that with my kooks ceramic coated. I really enjoy the kooks though.
Old Feb 6, 2011 | 02:40 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Lower under hood temps, better scavenging, looks purdy:
Old Feb 6, 2011 | 08:27 AM
EuroRod's Avatar
EuroRod
Using hearder wrap on non coated headers is asking for an early rust issue especially if the car is driven in the rain. The wrap will retain moisture, and accelerate rust.
Coat them suckers and they may last the life of the car.
And, they do look purdy!
Old Feb 6, 2011 | 01:44 PM
BowTieBlood's Avatar
BowTieBlood
My headers are not coated and I haven't noticed any rise in temperature guage wise or under the hood....but I have not actually measured it.
Old Feb 6, 2011 | 02:18 PM
ErnieN85's Avatar
ErnieN85
it's not that it gets hotter , it is that coated headers make it cooler by trapping the heat in the exhaust where it belongs.
Old Feb 6, 2011 | 02:23 PM
timd38's Avatar
timd38
I like the look of coated headers, but the company that made my headers said I wasting my money. That being said, I may have them coated when I take the heads off, just because....
Old Feb 6, 2011 | 02:25 PM
LS1LT1's Avatar
LS1LT1
Even without the coating a good quality stainless steel (304, 317 etc.) header can still last the life of the car as well.
Old Feb 6, 2011 | 03:16 PM
Mike V.'s Avatar
Mike V.
Default Winner!
This is the correct answer, but personal choice rules, no real benefit, but lotsa theoretical stuff re: lower under hood temp., effect on exh. gas temp, blah, blah, blah. Real world & no real diff., but if the extra $$$ doesn't bother you & you like the looks, knock yourself out. It surely won't adversely affect anything. My money is spent to make the rear of my car visable.
Old Feb 6, 2011 | 04:57 PM
Ragtop 99's Avatar
Ragtop 99
The cabin already gets plenty warm. If I were doing it again, I'd coat them and the X pipe just to help with that.
Old Feb 6, 2011 | 05:21 PM
timd38's Avatar
timd38
I have ceramic coated tunnel plate and it made a huge difference in cabin heat. Candy bars melted in the center console before headers and the plate, but they don't now.
Old Feb 6, 2011 | 05:37 PM
Mike V.'s Avatar
Mike V.
Default Valid points
Last 2 post, I was speaking from a perf. perspective & longevity. Keeping things cooler in the cabin, hell anywhere, is a valid reason to coat. The proximatey to the starter & fluid lines on passenger side may be reason enough.
Old Feb 9, 2011 | 09:18 PM
ScottJ03's Avatar
ScottJ03
Default Me too!
I have Kook's heat treated and look like new for 4 years and no discoloring
Old Feb 10, 2011 | 01:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Most header manufactures will NOT warranty your headers (if they have a warranty) if you wrap them. It causes them to rot out prematurely (even stainless headers will rust ) and cause the metal to get very brittle and crack in areas where the temps are excessively high (bends in the piping)
BC
Old Feb 10, 2011 | 03:27 PM
Vito.A's Avatar
Vito.A
It is not necessary to coat a quality stainless steel header (Kooks, American Racing, or LG). If you get mild steel, then you should coat them.
To reduce heat, you really need to coat the inside of the tube and that is just not possible on todays long primary tube design. They can get the first 8 inches inside the primaries on each end, but nothing more. Additionally, long tube headers moves the cats to the mid pipe and you cannot coat the inside of the cats or you will contaminate the cataylist.
Old Feb 10, 2011 | 03:56 PM
LS1LT1's Avatar
LS1LT1
Some might even say that coating them can potentially cause those same results as well...though if done correctly I don't see how any moisture can get in between the stainless steel and the coating.
Good points.
Old Feb 10, 2011 | 05:31 PM
Boomer111's Avatar
Boomer111
Not necessary to coat headers if quality SS. Ya coated looks good to some but I like the heat treated tubes myself. Got to look pretty hard to see them anyway after the hood is opened.
To Coated vs. Non-Coated Headers....
