This is the second time I've gotten this code, the first time was @ 7k miles or so and completely stock, I took it to the dealer and they really couldn't figure it out just did a software update and said it's still running a bit lean but could be because the car hadn't been driven much and just told me to use chevron w techron and to put some miles on it now 5k later same issue... Any ideas???
Ok I'll give that a shot, now I was told that it takes the car having the same issue occur multiple times before it throws a code ie(it took 5k to reoccur) is it safe to be driving it around like that? I had a similar issue in my c5z running lean on bank 1 and the motor ended up grenading on me?
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
I think it sets a code after the second consecutive failure. Does it idle roughly? If you have a scan tool you should be able to run down a check list which includes the items already suggested.
There can also be a small vaccum leak, weak injector or oxygen sensor electrical connector shorting out against the exhaust.
Your profile lists a cam & tune. A lean condition in a car with a cam & tune can be very dangerous so I would take car of it as soon as possible.
My C5z has the cam n tune but the C6 is pretty much stock just a CAI and it originally threw the code bone stock and now again w the CAI. It doesn't idle roughly but occasionally it will surge drops down to 500 and then back to normal...
My mistake.... check a previously outlined. It could also be a small blockage (debris in front of the MAf or a loose connector)
Get someone to scan the car and check the LTFT on Bank 1. It will be obvious if there is a problem on 1 side only. If there is it cannot be anything related to the MAF. As stated already switch front 02's and then check for vacuum leaks. These are by far the most likely culprits
I'm gonna drop the car off at the dealer since its still under warranty but what's the LTFT?
It stands for Long Term Fuel Trim. The computer can adjust fuel up to 25% up or down in the long terms, and once it gets to +25% and cannot adjust anymore then it throws the lean bank code you are getting. In other words it is reading way too lean to likely be anything besides a bad 02 sensor, vacuum leak, or MAF problem. But if it was the MAF both sides would be reading +25% and you would probably be throwing a MAF code in addition to the lean code.
The MAF cannot cause only 1 bank to be off anymore than just a little bit from side to side. Hope this helps
-Check your MAF sensor,clean it or replace it
-Swap out your Front O2 sensors from left to right and see if it chases the problem to the other side
do this first, usually the sensors go lean when they are going bad. Remember it doesnt read fuel at all it reads oxygen so a vacuum leak or hose off can cause issues as well.
So I got the car back from the dealer yesterday and it turns out the #5 injector was bad... Wouldn't have expected that after only 13K but S**t happens, just glad to have her back on the road now time for some new tires !
