LS2/LS7 header bolts = LS1/LS6?
Old Feb 8, 2011 | 05:06 PM
BluV's Avatar
BluV
St. Jude Donor '09-'10
Default LS2/LS7 header bolts = LS1/LS6?
OK, so I am finally getting tired of retightening header bolts. Thought it would be ok - but after doing it every 2 weeks for well over a year - finally got old.
Browsing the Summit Racing catalog, I see several variations on a theme....but they are all LS1/LS6. Are these the same as LS2?
I tried a search - but searching on headers and/or bolts - you get the idea. Adding "retainer" to the search resulted in 0 hits.
Or if you have a different suggestion...
Thanks in advance.
Old Feb 8, 2011 | 09:17 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
I bought some stage 8 locking header bolts for my not yet installed headers from Maryland Speed. If you check their site, you should be able to find or deduce the correct info.
Sorry I can't give you a direct answer, but it is definitely a starting point!
Old Feb 9, 2011 | 03:05 PM
AS10TRK's Avatar
AS10TRK
According to Maryland Speeds Website for the "Stage 8 Locking Header Bolts" the same size fits all of the LS engines. Good luck.
Old Feb 9, 2011 | 03:59 PM
BluV's Avatar
BluV
Great! Thanks to you both!
To LS2/LS7 header bolts = LS1/LS6?
