Ported Head vs Bigger Valves
Old Feb 11, 2011 | 10:25 PM
sallen619's Avatar
sallen619
Default Ported Head vs Bigger Valves
Which would yield better HP results.
Mildly Ported Stock 243 Heads(By Hand) or a Valve Job(Larger Valves)?
Old Feb 11, 2011 | 11:02 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Bigger valved won't help unless the area below the valve is opened up.
The other important thing about bigger valves is they may actually reduce air flow because of "shrouding" of the valve. This means the valve may be very close to the cylinder wall or combustion chamber thus restricting air flow. A smaller valve may actually flow better under this case.
If you look closely at CFM specs of ported or after market heads, they often state what cylinder diameter is used. If the flow numbers listed are on a larger cylinder than your engine, it may not be the best head for you.
Conclusion: Bigger valves don't necessary mean more flow and power.
Old Feb 11, 2011 | 11:35 PM
Stang's Bane's Avatar
Stang's Bane
Yes, if the port isn't changed for the bigger valve, you gain nothing.
FWIW, you can do a valve.job on the stock size valve and if done properly, that yields excellent gains.
Old Feb 11, 2011 | 11:48 PM
sallen619's Avatar
sallen619
What would this valve job consist of?
Old Feb 12, 2011 | 12:01 AM
Mez's Avatar
Mez
Multi-angle cuts to the throat (3 angle to 5 angle) with a back cut to the valve to increase air flow at low valve lifts. Hand blending of the cuts.
Link:
http://www.alaniztechnologies.com/headterms.html
To Ported Head vs Bigger Valves
