torque tube Help
Old Feb 12, 2011 | 04:26 PM
Schoolteacher's Avatar
Schoolteacher
Default torque tube Help
I am having trouble removing my torque tube. I have an 05 manual car. I have the tranny and rear out already. I have removed the bolts that hold it to the bell housing and slid it back 1". I went ahead and removed the two bolts that attach the slave cylinder to the torque tube but it just wont come out. Am I missing Something??? the shifter is already removed.
Old Feb 12, 2011 | 06:38 PM
RoadRebel's Avatar
RoadRebel
Rotate the tube clockwise as you are looking at it from the rear. When you get it to about the 2 oclock position you will see the rear wiring harness tucked into the tabs of the torque tube. Just pop it out with a long prybar and the tube will come right out.
Phil
Old Feb 12, 2011 | 06:56 PM
Schoolteacher
Thankyou!!! I will try this
Old Feb 13, 2011 | 08:55 PM
Schoolteacher
Still won't come out... Should I have to pry it off??
Old Feb 14, 2011 | 09:09 AM
RoadRebel's Avatar
RoadRebel
Have you popped the entire main harness out of the tabs on the torque tube? Its pretty big and runs the entire length of the tube from front to back. Also, on the top pass side is where the harness comes down from the motor and often hangs up on the top corner of the tube. Other than the slave and shifter which you seemed to have addressed, nothing is left that would hang it up.
Old Feb 14, 2011 | 09:37 AM
Schoolteacher
Thanks I will look again...
To torque tube Help
