LS3 cubic in. displacement
Old Feb 15, 2011 | 12:24 PM
white top's Avatar
white top
Default LS3 cubic in. displacement
GM says LS3 is 6.2 liters but I think they exagerate cause that would be 378.344 cu. in. When I calculate bore & stroke I dont get that high. What you all think ???
Old Feb 15, 2011 | 12:32 PM
RicK T's Avatar
RicK T
It's 376......but does it matter?
Old Feb 15, 2011 | 01:47 PM
LS1LT1's Avatar
LS1LT1
I've seen it listed anywhere from 376 to 378 cubic inches.
But the cars run like they have well over 400 cubic inches anyway so yeah, it doesn't really matter LOL.
Old Feb 15, 2011 | 01:54 PM
NYC6's Avatar
NYC6
Common practice from all the way back in auto history engine displacement numbers. Rounding up and down for different reasons was and is the norm.
Old Feb 15, 2011 | 01:55 PM
glass slipper's Avatar
glass slipper
The bore/stroke of an LS3 is 4.065" (or 10.325 cm) and 3.622" (or 9.2 cm). Displacement in liters is L=Bore²*Stroke*pi*2/1000 or L=10.325²*9.2*3.14*2/1000= 6.162L which rounds up to 6.2L, no exaggeration to it.
The LS7 is 427.65 in³ which is 428 in³ when rounded but GM calls it a 427 in³ because they truncate the number...their choice. The new Chrysler Hemi isn't actually a "Hemi" because the combustion chamber isn't truly hemishperical (it incorporates squish/quench areas for emissions) but it shares the same crossflow valve arrangement with the old Hemi from the 50's/60's...their choice. BMW calls their cars the "ultimate driving machine" when they are far from it...their choice.
Old Feb 15, 2011 | 02:01 PM
BLKCLOUD's Avatar
BLKCLOUD
Ford's original windsor 5.0 was only 4.942L, which would have/should have rounded DOWN to 4.9.
Just a little worthless information....
Old Feb 15, 2011 | 11:29 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
True. The classic Chevy 396 was actually about 402 if I recall correctly; however, management did not want to associate it with the old 409 Chevy, so picked the 396 number.
Lots and lots of examples like this out there.
Old Feb 16, 2011 | 12:26 AM
Rebel 1's Avatar
Rebel 1
You're partly correct. The big block 396 Chevy started in '65 with a 4.094 bore x 3.76 stroke = 396 cu. in.
In 1970 the bore was increased .030 to 4.126 = 402 cu. in.
What i heard was that management kept it at SS396 as not to "change a good thing". Insurance played a big part as well because anything over 400 cu.in. was more costly to insure.
Old Feb 16, 2011 | 01:15 AM
LS1LT1's Avatar
LS1LT1
And they possibly also didn't want to confuse it with the 400 small block that they'd recently introduced as well.
It always baffled me that they had 348, 366 and 396 (later becoming 402) big blocks and yet a 400 small block as well.
Now we have 427ci (or even 480+ci if you want to build it) small blocks.
True.
Old Feb 16, 2011 | 02:42 AM
Easy Rhino's Avatar
Easy Rhino
Thanks for correcting my memory on this bit of trivia
Old Feb 16, 2011 | 05:38 PM
Rebel 1's Avatar
Rebel 1
Welcome. If a person Really wanted to get into numbers, refer to the factories posting their "home-brewed" horsepower readings for "certain engines" for the past 40+ years.
Old Feb 16, 2011 | 09:04 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
The new 5.0 Ford motor is a good example. Rated at 412 hp, there are many dynoing 385-390 hp bone stock. That equates to more like 450-460 hp....same thing they did with the "Terminators".
Old Feb 16, 2011 | 10:17 PM
SpryGeezer's Avatar
SpryGeezer
Originally Posted by glass slipper
The bore/stroke of an LS3 is 4.065" (or 10.325 cm) and 3.622" (or 9.2 cm). Displacement in liters is L=Bore²*Stroke*pi*2/1000 or L=10.325²*9.2*3.14*2/1000= 6.162L which rounds up to 6.2L, no exaggeration to it.......
Yes, but only for an eight cylinder engine.
Old Feb 16, 2011 | 10:26 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
LMAO!!! So true!
Old Feb 17, 2011 | 03:21 AM
glass slipper
Read my post again...I was talking about the LS3 specifically. Last time I looked, it has eight cylinders.
Just for you, the displacement formula (in liters) for any engine is:
L=Bore²*Stroke*pi*(# of cylinders/4)/1000 with the bore/stroke in cm.
To LS3 cubic in. displacement
