Lowering and trimming front spoiler...
Old Feb 17, 2011 | 01:38 PM
bigred6906's Avatar
bigred6906
Default Lowering and trimming front spoiler...
Thinking about lowering my 2010 GS all the way on the stock bolts...Was wondering if trimming about an inch all the way across the front spoiler to avoid so much scraping would be a good or bad idea? Thoughts?
Old Feb 17, 2011 | 01:42 PM
6Speeder's Avatar
6Speeder
If the GS is a front breather, like the Z06, with the bottom before the radiator blocked off, YES!
Just unbolt the left and right sections, and cut off most of the center one. This will greatly reduce if not stop the scraping, and will aid your aerodynamics.
Old Feb 17, 2011 | 02:14 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Agree...might loose some mpg on the highway though. If that matters to you.
Make sure to keep the lower radiator block off piece IN PLACE.
Old Feb 17, 2011 | 02:32 PM
bigred6906's Avatar
bigred6906
So I can completely remove the two side pieces and just shave down the center one? No overheating issues or anything?
Old Feb 17, 2011 | 03:00 PM
6Speeder's Avatar
6Speeder
Nooverheating. The main reason for that air dam was to force air through the radiator via the bottom breather. If it's blocked off, what's the point?
Old Feb 17, 2011 | 10:30 PM
bigred6906's Avatar
bigred6906
So this can only be done on a GS or Z06 because of the way it's set up? Can't be done on a base coupe?
Old Feb 17, 2011 | 11:28 PM
Bill Dearborn's Avatar
Bill Dearborn
Just let it scrape. They are meant to be worn down. It will even itself out very quickly why bother cutting it yourself when it will buff itself down? By the way the spoiler helps build a high pressure area under the bumper to feed air into the brake ducts while also reducing air flow under the car thus reducing drag.
I will put it another way. GM didn't put those parts on there if they did not serve a purpose. They are not in the habit of just throwing parts on a car that don't serve a purpose. Car makers like GM look everywhere they can to reduce parts costs by pennies so saving a few bucks by not installing the spoiler would be easy pickings for a cost engineer.
Bill
Old Feb 18, 2011 | 12:10 AM
bosco 08's Avatar
bosco 08
Bill
^ someone gets it.
btw my 2008 is lowered as far as the stock bolts will go which is appox. 1/2" f/f. it won't hurt a thing if it scrapes sometimes in fact after a while it doesn't scape anymore.
Old Feb 18, 2011 | 08:37 AM
6Speeder's Avatar
6Speeder
The airdam creates a high pressure area under the nose of the car to force air into the radiator of a bottom breather (base car). Bad for aero (look at Katech's aero data), good for cooling. Not needed for a front breather. For a base car either leave it intact or try cutting it back to half height, but watch your temp gauge. They are cheap to replace, if you need to.
Old Feb 18, 2011 | 09:24 AM
haljensen's Avatar
haljensen
Bottom or front breather doesn't make much difference. Air will take the path of least resistance whether it's coming from the front or the bottom. The radiator core resists air flow so the air finds a way around (under the radiator) the resistance.
The air dam also has a big part in high speed handling, it keeps air out from underneath the body so the front end doesn't lift.
If you remove or cut the air dam you reduce air flow thru the radiator and increase front end lift at speed.
Old Feb 18, 2011 | 09:36 AM
Former Vendor
You can not do this to a base car because that air dam is there to help force air into the radiator.
Old Feb 18, 2011 | 09:39 AM
Former Vendor
Bill
GM put it on there to cut down drag and increase MPG, but it does increase front lift as well at speed. You said it right there....depends on what you want. Lift and MPG, or stablity and downforce
The other thing it does it helps to force air into the brake ducts. The ZR1 has most of this removed and they put a little 'scoop' so to speak on the control arms to help force the air into the brake duct from the opening on the front splitter.
Either way you can remove it, and it should help reduce front lift but it will increase drag.
Old Feb 18, 2011 | 05:36 PM
6Speeder's Avatar
6Speeder
The air dam is too far back under the nose to keep air from going underneath the car. All it does is back the air up into a high pressure area under the nose. If you remove it you will decrease front end lift at speed.
Old Feb 21, 2011 | 09:04 PM
marc8090's Avatar
marc8090
I have a base car and trimmed 3/4" off all 3 pieces and notice absolutely no difference in engine temps on very hot days while at highway speeds where the airdam could make a difference.
Old Feb 21, 2011 | 09:29 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
GM also says it's there to reduce pressure behind the radiator to make the cooling fan more effective. I would think that would be more important in city driving than any high speed benefits rarely seen by most cars.
Old Feb 21, 2011 | 10:48 PM
Zoxxo's Avatar
Zoxxo
There ya go.
We took 3/4" off of the center piece of my wife's base C6 vert (it was low and the scraping was driving her nuts) and we totally removed the end pieces. Zero change in the temp readings even on the hottest days (100+.) And since she isn't regularly road racing the thing, cracking 150 mph, or doing mutiple full-stop actions, the aero and brake cooling issues are pretty moot.
Bill, her car was scraping that center piece *hard* for three years (25k miles) and that piece had barely worn at all when I went under there to trim it' I was amazed.. I mean, essentially NO wear (!) I dunno what it's made from but it's much tougher material than folks think.
Z//
To Lowering and trimming front spoiler...
