Exhaust pop when shifting
Old Feb 19, 2011 | 10:10 AM
corvette-kyle's Avatar
corvette-kyle
Default Exhaust pop when shifting
During quick shifts from 1-2 or 2-3 sometimes I get a loud crack that comes from the exhaust. Sometimes I can get this to go away if I take my time shifting but I don't want to be the last one in the group on a green light. I don't really mind it but friends have commented that it doesn't sound too good so I just want to make sure it's not bad. I also have a really hard time with getting a smooth 1-2 shift unless I go really really slow, however all the other shifts are fine. User error or possibly mechanical error?
I'm also considering getting my 2008 split spoke wheels powdercoated black. Does anyone have any pictures or verify the process is as easy as I think it is - take all the wheels and tires off of the car and have them painted and then just put them back on? Do i need to get aligned or balanced if I'm just powdercoating?
I also watched a video that said for the C6's the clutch needs to be on the floor for it to fully disengage even though it feels like mine disengages 2-3 inches off the floor, and this was why some shifts are difficult. Is this true?
Thanks.
Old Feb 19, 2011 | 10:26 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Please post your mods and if the tune has been modified.
Old Feb 19, 2011 | 11:03 AM
seevi's Avatar
seevi
Thanks.
OEM exhaust, or has it been replaced?
Old Feb 19, 2011 | 11:31 AM
NYC6's Avatar
NYC6
powdercoating is a little more complicated than just painting. If you dont know, in a nut shell, the process consists of spraying the wheel with electrically charged powder then baking it in an oven to cure the finish. not something thats a DIY.
I have CCW wheels on mine that I bought that way from CCW. Over 2 years now and still look like the day I got them. I would certainly get the wheels balanced after remounting the tires. You shouldnt need an alignment at all.
Old Feb 19, 2011 | 01:43 PM
corvette-kyle
Exhaust is NPP with the fuse pulled. To my knowledge the car is completely stock as it is from the factory.
And with powdercoating I realize it's not "painting", I've got a quote from a powdercoater and all but I was just curious about whether I needed to balance and align or not after powdercoating.
Old Feb 19, 2011 | 02:30 PM
corvette-kyle
Okay, update. It's got Kooks long tube headers, with the high flow cats and X pipe. It's also been reprogrammed or tuned or whatever by Chuck COW from Corvette's of Westchester.
That probably makes a difference.
Old Feb 19, 2011 | 03:34 PM
BoosterClub's Avatar
BoosterClub
It's a backfire from fuel over-run or condensed fuel re-evaporating and entering the cylinders/exhaust.
It should be a lot more common then just every now and then too.
Cats act as suppressors to this though so maybe that's why only really big ones are getting through.
Old Feb 19, 2011 | 04:56 PM
Bill Dearborn's Avatar
Bill Dearborn
I doubt the popping is an issue. When I ran removed the mufflers and ran straight exhaust pipes on my 97 it would pop just like that and other than the mufflers being removed it was totally stock. Not sure but I think my 08Z will pop a little when I shift at high rpms while on a road course but it is hard to hear over all the wind noise.
Bill
Old Feb 19, 2011 | 06:54 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
Normal and should be happening a lot with the headers. I love the gurgle and pop.
Old Feb 20, 2011 | 11:22 AM
cclive's Avatar
cclive
We like the pop and gurgle....
Old Feb 20, 2011 | 11:42 AM
Mez's Avatar
Mez
The PCM has tables for ignition advance and Deceloration Fuel Cut-Off or (DFCO) that can be modified to reduce the exhaust popping. The problem is fuel continues to be injected when you are at elevated RPM and the ignition is retarded after TDC, so raw fuel is going out the exhaust system and getting ignited down the line.
I have headers and Corsa Sport cat-back and there is some burbling but its not obnoxious, so I've have left it alone.
Old Feb 20, 2011 | 11:46 AM
BoosterClub
Define elevated? I'm pretty sure no fuel is injected at say 3-4k rpm decel and there is substantial popping there. .
Old Feb 20, 2011 | 01:04 PM
Mez's Avatar
Mez
I would say 3000 to 4000 rpm is elevated.
Fuel is being injected otherwise how would it be popping?
Old Feb 20, 2011 | 01:58 PM
BoosterClub
Quite a lot of popping and gurgling can come just from over run and puddled fuel re evaporating. Quite a lot of fuel remains in the intake runner after letting off the throttle that then goes through the engine and exhaust. There would be a problem if their was fuel injection and ignition even past TDC while decelerating.
Car's don't normally inject fuel on deceleration though, I don't remember there being an "elevated RPM" disable of this, but I'll check when I get home.
Old Feb 20, 2011 | 04:33 PM
corvette-kyle
I actually read up on the whole changing the clutch fluid thing awhile ago and just got around to it today. Flushing the clutch fluid with Prestone Dot 4 from Walmart ($3) it completely removed the difficult 1-2 shift and also smoothed out everything in general. My clutch fluid was completely black and at the minimum level, and I have been driving all day enjoying the car. It feels brand new.
I've noticed the popping only really occurs between 1-3k rpm, if I downshift to second gear and let off the throttle it will smoothly roll down until around 2.5k rpm then start popping. I like the popping and gurgling, just wanted to make sure it was normal. I am still getting a single loud pop when I shift occasionally, and when this happens it happens when I move the shift ****, not when I re-engage the clutch.
Old Feb 20, 2011 | 08:31 PM
Mez's Avatar
Mez
Speed and RPM are part of the DFCO algorithm. Other things that determine when it kicks in are gear, throttle position, and g/cyl (air). Also, it backs the ignition advance down.
Old Feb 20, 2011 | 09:20 PM
BoosterClub
Speed is for it to be active above a certain speed, a really low MPH
RPM same thing, it stops at like 1200 rpm because obviously you have to start idling eventually.
TPS is to make certain you are off throttle.
g/cyl same thing in case you had some sort of a failure. of throttle or leak to.
None of these things serve to inject fuel during decel, it's the opposite obviously. I also checked and it is above 6000 rpm for DFCO to shut off and be injecting during decel, I don't know anyone who lets completely off above 6k, and if they do they shouldn't be, it's a bad habit that can snap connecting rods.
In other words if you're decelerating off throttle, no fuel is being injected. So again the pops are from overrun and evaporating fuel.
To Exhaust pop when shifting
Old Feb 20, 2011 | 10:44 PM
Mez's Avatar
Mez
Where are you getting your information from?
Old Feb 21, 2011 | 02:24 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Gotta love it!
Gotta love it! Borlas I hope!
Chuck CoW
Old Feb 21, 2011 | 05:35 PM
BoosterClub
I don't understand why you are asking, you seem to have hptuners, you can see for yourself.
