From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Originally Posted by BoosterClub
I don't understand why you are asking, you seem to have hptuners, you can see for yourself.
Yes, I've tuned my own car. Mine bubbles and pops a little but its not obnoxious.
Are you tuning yours? Have you looked at the DFCO? Do you have a scan to send me?
What about the ignition advance table? The stock tune goes negative which means the exhaust valve is open before spark and whatever fuel is in the combustion chamber goes out the exhaust before spark. This helps keeps the cat's and NBO2 sensors hot.
Like I said, having HPtuners you should be able to see how the DFCO works, I suspect maybe you don't realize what DFCO is? You said:
Originally Posted by Mez
The problem is fuel continues to be injected when you are at elevated RPM and the ignition is retarded after TDC, so raw fuel is going out the exhaust system and getting ignited down the line.
But this isn't so, That's the whole point of DFCO, to stop the fuel during decel, the burbling and popping is from overrun and evaporating fuel, not from ongoing injection.
