DIY Throttle Body
Old Feb 20, 2011 | 08:53 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Default DIY Throttle Body
Quick question....
I want to swap out my throttle body with a ported/polished unit. Is this a hard thing to do (for a non-mechanic - but a mechanically inclined person)? I like to do these projects but I won't start something I can't finish.
Do I have to tune it after install? Or is it just bolt on? (Actually, that is the game changer as to this project being a DIY).
Thanks.
Old Feb 20, 2011 | 09:55 AM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
This is a pretty cheap mod, buy one already done from a forum vendor then send them your core and your done! No need to tune for this as long as you put a properly porter unit on.
Old Feb 20, 2011 | 11:50 AM
80&09vettes's Avatar
80&09vettes
I replaced my stock TB with a VMax throttle body. It's an easy mod and takes about 45 minutes. No special tools required. Great bang for the buck improvement as you will notice crispter throttle response.
Old Feb 20, 2011 | 01:52 PM
Mike V.'s Avatar
Mike V.
Default Go for it.
If you're mechanically inclined, it's very simple. Depending on your intake manifold, be sure to check the gasket between the 2 remains intact, once it comes out, it really won't go back in because it stretches & won't fit the orig. indent. A quick fix, oppose to a new gasket, is to cut opposing 45 degrees decreasing the dameter to fit back in the detent & put a dab of orange permatex in to seal for sure. Although a new gasket is better. If maintains placement on the manifold, no worries, put 'em back together, done. I have a FAST intake, a spacer, between TB & they're notorious for leaking. Vacuum leak = PIA, CEL, & headache!
Old Feb 20, 2011 | 04:44 PM
383's Avatar
383
How much of a gain can be expected from porting the TB? How big can you go before it starts to decrease output/velocity?
Old Feb 20, 2011 | 06:11 PM
victorf's Avatar
victorf
Default Cut 45*
I don't mean to come across as being disrespectful, just want to learn something from your post.
Please elaborate on:-
1. How you can "cut opposing 45 degrees decreasing the dameter" remove material while decreasing the diameter at the same time?
2. What method you use to make this 45* cut?
3. Will the 45* end cut be concentric?
TIA
Old Feb 20, 2011 | 06:49 PM
victorf's Avatar
victorf
Originally Posted by davidtcpa
Quick question....
Thanks.
The process is simple.
1. Disconnect negative battery cable.
2. Disconnect electrical plug from TB motor.
3. Disconnect valve cover vent from accordion tube.
4. Disconnect electrical plug from MAF.
5. Now you can unscrew band clamp and separate air intake from TB.
6. Loosen and remove four bolts that secure TB to intake manifold, take care while removing TB (sealing surface of TB has sharp edges) from intake manifold.
Most people reuse original gasket and normally it takes a set and remains in groove. Just cheap insurance, I like to use new gasket.
With the addition of 89 in/lb of torque on the four TB bolts, re- installation is the reverse of removal process . I believe torque is important as "O" ring type seal requires only .005" squeeze to achieve designed seal.
And to your last question in regards to re tune, if properly ported, only in a few rare cases required.
Hope that helps.
Old Feb 20, 2011 | 08:39 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
It is a super easy mod....but honestly I think it's a waste of money. I have one and it didn't do anything, dyno, track or even sotp.
You will get a real gain from a CAI if you have a ls2 that you will notice especially in the summer.
Old Feb 20, 2011 | 08:46 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
You are the first one to tell me you don't feel a difference from porting the throttle body. Interesting that you noticed nothing.
I already have a cai and headers. I am going to do many more mods, but this one seemed like a cool easy project I can do with my son. Kind of a bonding thing!!!!
Old Feb 20, 2011 | 09:09 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I noticed nothing and I was looking for some effect. When I got my 05 I noticed the throttle response was sluggish and I was having trouble heel and toe shifting. I tried a throttle body, a tune, nothing made a difference.
Finally after 4 years HP tuners came out with a throttle opening rate table and sure enough the 05's are tuned sluggish from the factory. That finally helped me. Your car isn't tuned sluggish btw. Just 05's.
If you want a mod that will matter and is easy get a fast 102 intake. I helped Justasheet put one on last tues, took about 20 minutes on the dyno to do it. I've done a bunch though and know the tricks. It's easy... Jaysplay just posted up a how to thread.
You feel the fast...the ls2 intake is so bad. The fast is a great mod.
Old Feb 20, 2011 | 09:26 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
I think that a FAST intake is too much for me to do myself, and considering the amount of money I have put into my car in the last 5 months (widebooty, headers, fusions, cai, blackout, UD pulley, etc),I did not want to spend another 1+K for the FAST, plus install. I wish I could do that myself, but....
So the PTB is an inexpensive mod that people are saying gives them increased throttle reponsiveness.
Unless you want to help me install it!!! LOL
Old Feb 20, 2011 | 09:44 PM
Mike V.'s Avatar
Mike V.
Default Here goes...
TIA
Perhaps it is just worded confusingly, basically you have a perfect circle. If you pull the rubber gasket it stretches, even the slightest amount will make it impossible to put back it in. Thus the diameter must be cut, the cut will look like this / / except of course 45 degrees (one 45 cut leaves 2 opposing 45s). Making the cut 45 degrees as the gasket lays flat will provide a lap over, so even if too long it will crush into place. Conversely a 90 (concentric) too long accoplishes nothing, too short guarenteed leak. Concentric by definition would look like this | |. Once you made the cut re-install w/o removing any, see how much overlap occurs from stretching, err to the side of cutting too little (you can cut more, but can't add back). Orance (red) RTV is petrolium product resistent just to be safe. Hell you can make the whole gasket using orange (red) RTV if you like. Lay a bead like caulk. This seems like way too much explaination when it's just plain COMMON SENSE.
Old Feb 20, 2011 | 09:56 PM
Mike V.'s Avatar
Mike V.
Default It looks way more daunting...
... than it actually is, but if your not comfortable, it's a wise thing to know your limitations. There are some excptional DIY posts out there. Conversely, it's also easy to make a simple mistake & complicate your life. I know plenty of people who broke the oil sending unit doing an intake removing or installing for example.
Old Feb 20, 2011 | 10:03 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Well, as a fellow CPA I hate to see you waste your money. PTB has no dyno gain and sotp gain is dubious at best, and non existent in my case. People very seldom admit a mod they spend money on didn't do anything...and throttle response is pretty hard to measure (unless you heel and toe like I do).
Check this out. It's not a hard job. If you would like to tackle it and want a hand I could help you out. Horsepower Sales also doesn't charge much for the install if you don't want to tackle it because it's easy.
You do need to tune after you put it on, hps can do that for you. It will change things enough to warrant a tune touch up.
http://forums.corvetteforum.com/c6-t...with-pics.html
Hey Mike V......think the fast is worth it?
Old Feb 21, 2011 | 03:19 AM
SouthTexasBully's Avatar
SouthTexasBully
No Mike V here but i will say that a fast 102 is without a doubt worth it..i got close to 20 rwhp,just as much TQ,sotp,and time slips..the fast 102 is a REALLY good mod..hope this helps...STB
Old Feb 21, 2011 | 08:44 AM
Motorhead-47's Avatar
Motorhead-47
Tried this several years ago as one of my first mods...IMHO...waste of money. I swapped my ported TB even-up back to a stock one. The ported one threw off my "ETC Area Scalar" value in the tune and created tuning issues for me. Back to stock...problem resolved.
Old Feb 21, 2011 | 10:47 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
Thanks guys. I need to go with my original plan and just SC the motor!!! Forget the ported TB, forget the gears (maybe). The SC has a little wow factor as an added bonus.
I will have to wait for that one $$$$!!
To DIY Throttle Body
Old Feb 21, 2011 | 10:51 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
Default By the way..
Joe_G, can I safely assume that we have broken the mold as pocket-protector wearing CPA's?? A nice Vette suits me much better! Where in FTL is your ofiice?
Old Feb 21, 2011 | 12:01 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
Is this all I would need? Or are other parts involved. It is much more that 100 for the ported tb!!
http://forums.corvetteforum.com/c5-p...ls7-truck.html
Old Feb 21, 2011 | 11:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I ported an polished my own and installed it with my header and VARARAM install. I had a tune done after all the mods were installed at once so, I can not comment on it specifically.
For me, it was a vey simple install. NO issues what so ever.
BC
