Tech tire question
Old Feb 21, 2011 | 11:51 PM
ibassez's Avatar
ibassez
Default Tech tire question
ok i have a 06 vette with 19,500 miles on it and my tires are bald. is this common ? looks like the orginal Goodyears?? please help me out . thanks mike
Old Feb 22, 2011 | 12:17 AM
djbrun's Avatar
djbrun
Sounds about right. If you are concerned about tread life, you would need to look at the tread rating. (example: 300) The higher the number, the longer the tire will last but also will probably suffer performance qualities.
Do a search of tire rack and look at the possible tires offered for our cars and compare the performance verses mileage if that is important to you. You should be able to make a decision from that.
DJ
Old Feb 22, 2011 | 12:38 AM
ibassez's Avatar
ibassez
ok good cause i bought the car used. just wanted to know if it was common cause i looked fishy but the tires are 5 years old now. and its a vette im sure they run quicker than my honda element
Old Feb 22, 2011 | 04:07 PM
TorontoC6's Avatar
TorontoC6
It's common. Z51 cars come standard with Goodyear F1 Supercar tires whereas the stock coupe comes with Goodyear GS-2 tires. The Supercar tires don't last long (220 rating), typically just over 10,000 miles depending upon how you drive. The GS-2's last longer (300 rating). Whatever you buy, they typically last less than tires on 'regular' cars. If you are looking for a decent set of street tires that have reasonable grip and longetivity, look at the Hankook Ventus V12.
Good luck.
To Tech tire question
