Rear tires
Old Feb 24, 2011 | 11:24 AM
mlhancocksr's Avatar
mlhancocksr
4th Gear
Default Rear tires
I have 7,000 miles on my Z06 I took it to my dealer for oil change and was told that the right rear tire was worn out and the left rear had 70% wear left. The dealer said I am not pushing car hard enough. I am stumped as I only drive it on long road trips and to church. The car have Good Year run-flats on it. Has anyone experienced this problem and what can be done about it, As an old mechanic, I think I have a differental problem, not a driver problem. Please comment.
Thanks,
Myron
Old Feb 24, 2011 | 11:55 AM
RicK T's Avatar
RicK T
Welcome to the Forum!!!!!!!!
I'm thinking it might be an alignment issue. Have you ever had the alignment checked or done?
Also, you might post in the Z06 Forum and talk to the guys who own them. Just a suggestion. Good luck.
http://forums.corvetteforum.com/c6-z06-discussion-100/
Old Feb 24, 2011 | 01:35 PM
Bill Dearborn's Avatar
Bill Dearborn
Thanks,
Myron
What does the wear look like. Most of the Zs I have seen (mine included) tend to wear the outside of the rear tires. I have a lot of negative camber in the rear and the outside edges still wore out because there was too much rear toe in. When you get on and off the throttle does the car twist in one direction or another, is the steering wheel off center when you are driving down the road?
One thing that can happen is the camber adjustment cam slipping. If that happens on one side a tire could be severely toed in on that side. That should affect the thrust angle and steering wheel position but if somebody adjusted the front toe to compensate then you wouldn't know.
Bill
Old Feb 25, 2011 | 12:35 PM
seevi's Avatar
seevi
Thanks,
Myron
Where do you live?
Old Feb 25, 2011 | 12:41 PM
mlhancocksr
4th Gear
I live in Hayden, Al North of Birmingham about 40 miles
To Rear tires
