I was wondering if it's possible to install stock Z06 exhaust (dual mode) with pipes on my '09 C6 coupe. If so, will it fit nicely or I need some slicing and hard work done? And which model of Z06 will do the job?
You can do it but it does require "some" work. Adding just the Z06 mufflers is no big deal, but you know you need an after market vacuum control for the dual-mode to work. For the rest of the pipes, if you have an auto trans in your '09 then the Z06 pipes won't fit around the trans so you have to stay with your stock set up. Here are a couple of threads for info, if you need more detail just ask, lots of members here have done it:
