coolant change
Old Feb 26, 2011 | 12:10 AM
RedZR's Avatar
RedZR
Default coolant change
I am looking for some help with a maintenance item- changing my coolant.
I have read some posts where the process is basically a "drain and refill" deal while others elude to a set of instructions from GM where you must burp the system by running the car at a certain rpm.
Could someone tell me what the correct way to change the coolant is, please?
Dan
Old Feb 26, 2011 | 08:53 AM
Ragtop 99's Avatar
Ragtop 99
http://forums.corvetteforum.com/c6-t...ocedure-q.html
Old Feb 26, 2011 | 10:56 AM
Kenny94945's Avatar
Kenny94945
Strong vote to use distilled water to mix the coolant ratio.
To coolant change
