What upgrades??
There are two different distinct camps on this one.
The TRACK guys (who are a small minority of the overall Corvette community) and the STREET guys.
Speak to SPINMONSTER on this forum. He's someone who is VERY credible and will likely agree with me.
The vast majority of the Corvette market could care less about track times and dyno numbers.
As hard a concept as this might be to swallow for the "track guys", YES most people don't care about dyno numbers and track times.
When spending my customers money on mods that will make their cars MORE enjoyable (yes, ENJOYABLE being the key word here) for
them to drive (especially 0-60 stuff) the gears cost about the same as the headers and the gears will always make the car much more
exciting to drive than the headers.
Again, we love headers, but you have to know what you're wanting....
Headers just DO NOT give you that torquey, exciting feeling that you get when you install gears in a vehicle.
This is not applicable. Different cars with different power levels, mods, and usage will yield different results.
Chuck CoW
I've also spoken to Spin a few times on the phone about my car and I can take credit that if he ever decides to buy an A6 it'll be because of what I've done with mine. (Spin, if you happen to read this and I've misquoted you in any way please feel free to set the record straight.
)I do however disagree (see, I knew the good times wouldn't last) with what you said regarding my results being not applicable. While it's true that different cars will certainly yield different results, I was providing a benchmark to illustrate the difference on the same car in the same conditions in the same application.
If I only saw a difference of slightly over a tenth in the quarter mile with my setup, the average person can use that to reasonably conclude the type of gains they'd likely see in relation to their power level. As an example, a twin turbo setup might see as much as two tenths at the track whereas somebody with a lightly modded LS2 or LS3 might see slightly under a tenth. It was just to establish a frame of reference, that's all.
Realize that if every customer was a quarter mile/dyno guy, I would have to evaluate each case differently. (and I think SPIN would also AGREE
) that the best foundation for just about ANY application - including RACING is a lower than stock Diff ratio.
Not unlike a converter, it permits you to operate at a higher rpm and stay in your "power window" better.
I'm sure we'll both agree, just about ANY Vette with gears will be more fun on the street than without them. Most guys that made the switch
to a lower ratio, would NEVER switch back.
Chuck CoW
Chuck CoW
Chuck CoW
Based on those same set of scans I was able to calculate the difference in 0-60MPH times which a lot of people out there can relate to.
With the 2.56s the average 0-60 time was 2.906 seconds and with the 3.42s it 2.594. This data was obtained by looking at the average across several different scans, all with a good clean launch.
Do you know if there are any other such "irregularities" on say a GS Vert/Auto/Heritage Pkg (looking at an '11 w/out F55, so I'm still scratchin' m'head 'bout THAT gal)? Or for that matter, ANY of the other '10-'11 models choked up like that? Actually, now that I think of it, I've also been looking at a relatively cheap, low mi '09 ZO6, & I wonder if that one suffers from the same ***-phixia as the ZR1? I will be changing the gears on whatever C6 I end up with though, too.
Best regards,
...z
Best regards,
...z
Well, for instance.... If you have ANY C6Z or NPP system you'll notice that even if it's got a full 3" system from front to back, the pipe is swedged down to 2.5" going into the mufflers...
All of them are like that.
Chuck CoW
