New install C6 LS2, E Force, Headers, Cam, 3.50
Old Mar 1, 2011 | 04:07 PM
-fate-'s Avatar
-fate-
Default New install C6 LS2, E Force, Headers, Cam, 3.50
Ok got all my parts..... this should be good. C6 LS2, E Force 599HP kit, Z06 pump Headers, Corsa Extremes, fast cats, Lunati Cam kit, 3.50 pulley, Beehive. This is a A6 Z51 car. Wish me luck I trust these parts and it should all work together. I will report in about a week..............I hope.
fate
Old Mar 1, 2011 | 04:23 PM
Motorhead-47's Avatar
Motorhead-47
fate
Do-It-Yourself?
Old Mar 1, 2011 | 05:04 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
Hope the install goes well!!
Old Mar 1, 2011 | 05:24 PM
-fate-'s Avatar
-fate-
No this one is over my head Nice local dealer is up to it and can really tune. This has been really researched and should go well. It is also all I am willing to do on stock underpinning. I just want to make it a strong driver with this A6.
Old Mar 1, 2011 | 05:27 PM
-fate-'s Avatar
-fate-
motorhead
Have you got the E Force on your car ?
Old Mar 1, 2011 | 05:37 PM
Motorhead-47
motorhead
Yep...installed it last March...car already had headers and mild cam at the time. 2009 LS3 MN6 with the 599 kit but I've recently gone to a smaller pulley (3.25") and larger fuel injectors (65lb)...traction is now history
Old Mar 1, 2011 | 05:55 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I am jealous.....
Gotta save up for that!!! Just an Eforce shy....
Old Mar 2, 2011 | 01:28 AM
5knives's Avatar
5knives
How much power are you putting down?
Old Mar 2, 2011 | 06:53 AM
Motorhead-47
To be honest, I don't know. The car has not been on the dyno since the install of the smaller 3.25" pulley and larger injectors. The smaller pulley added about 1.5 psi. The larger injectors were needed to lower the injector duty cycle. With my mods I was running out of injector with the 52lb injectors that came with the #1591 kit. Coolhand 5599 has a nearly identical setup (although his has an A6 and mine an MN6) and he last dyno'd right at 600rwhp if that helps. He's also had his car to the track on several occasions. Keep in mind he has a Grand Sport (heaviest of the pack), he added over 100lbs of Dyna Mat when he upgraded the stereo, and he still came home with a couple of 10.3x time slips...not too bad.
Old Mar 2, 2011 | 10:42 AM
-fate-'s Avatar
-fate-
Street manners stay OK and do you have any heat issues ? I was thinking about adding the Beehive to restrict the underhood heat from getting to the blower 1st hand.
Old Mar 2, 2011 | 05:52 PM
-fate-'s Avatar
-fate-
Sorry guys about the thread in the wrong place. I just found the FI portion.
Old Mar 2, 2011 | 05:55 PM
Motorhead-47
Any adverse street manners will come from your cam selection...absolutely zero bad manners with the Edelbrock without a cam! Mine has a cam....ever so slight fuel small at idle and the occasional mild surge when I'm running around in the wrong (too high) gear.
Add the BeeHive and trim the shroud...effectively creates a cold air intake for the Edelbrock.
Superchargers produce heat...sit still in traffic with any supercharger and you'll get inlet air temps high enough for the car to start reducing timing. This is also true with a stock car but very few guys bother to watch IATs on a stock setup. It's all about sizing the heat exchanger for it's job.
Old Mar 3, 2011 | 10:31 AM
-fate-'s Avatar
-fate-
Thanks, very good information. I have the Beehive shroud and I see how to trim it. My cam is mild. Thanks for the help.
This is really rough to see happening to your baby
BTW motorhead USAF PJ retired here <S> your service.
Old Mar 3, 2011 | 11:24 AM
Motorhead-47
A PJ!...bet you have more than a couple of war stories to tell!!
You'll need to cut the last two inches off the Beehive on the passenger side where it runs down along the radiator. There is a cooling line for the sc heat exchanger there that would otherwise be in the way.
Also you want to open a couple of vent holes in the black plastic shroud in front of the radiator for fresh air...works well.
Old Mar 3, 2011 | 12:21 PM
-fate-'s Avatar
-fate-
LOL yeah a few, 70%er here they put me out in '72 got a son thats a Cake Eater out of Nav Acd flying Super Hornets.
BTW that 2nd tour is how I got the handle "fate" I should not have tried that
<S>
Old Mar 30, 2012 | 10:29 PM
383's Avatar
383
Well????
To New install C6 LS2, E Force, Headers, Cam, 3.50
