05 differential, how bad are they?
Old Mar 2, 2011 | 11:28 AM
thebean's Avatar
thebean
Default 05 differential, how bad are they?
Just purchased an MN6 05 and had planned on supercharging it. Was not to happy to find out after purchasing that the 05 has a weak differential. Now not only am I thinking it would be a bad move to add a supercharger I am thinking it might be best to sell and get a 06-07.
So is the weak differential overblown? Car will be street driven only no sticky drag tires.
Old Mar 2, 2011 | 12:08 PM
stalker26's Avatar
stalker26
I just had this issue about a week ago believe it or not. I fully built my motor and no more than two days later bam, cracked my rear diff housing... I got the tip to call RPM Transmissions 765-378-0625 and they hooked me up fat. They have some special on us 05 guys. He said they felt bad for us and gave me a bad *** discount.. give them a call and let them know what you have and I gurantee they will be more than happy to help. Great guys
Old Mar 2, 2011 | 12:13 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
The 05 MN6 car has the weakest diff of them all from what I read. It is cheaper to upgrade than replace since you currently have a useable core, and simply upgrading the diff will certainly be less hassle than replacing the entire car IMHO.
Old Mar 2, 2011 | 12:15 PM
RicK T's Avatar
RicK T
I agree, don't sell the car as long as it's one you like, just do a differential upgrade, either the standard '06+ C6, a Z06, or RPM's. Just an opinion. Good luck.
Old Mar 2, 2011 | 12:16 PM
stalker26's Avatar
stalker26
By the way, I got my diff package in from RPM and it works great... couldnt be happier
Old Mar 2, 2011 | 01:01 PM
richgoat's Avatar
richgoat
plenty of guys running blowers on their 05s without issues. I think as long as you don't drag it, you'll be alright with highway pulls. From what I have read, wheel hop is the main culprit. But, I like you have an 05 and I'll do a preventative upgrade down the road after I get the blower on.
Old Mar 2, 2011 | 01:25 PM
7795TAs's Avatar
7795TAs
I have an 05 and do not plan on doing anything major to the motor and am going to put a brase on the diff. I hope that will be enough. I don't track or race my car so I should be fine. If it does break ill deal with it.
Old Mar 2, 2011 | 01:30 PM
BT03mach-1's Avatar
BT03mach-1
i have a 05 and mine is still together. I have made a lot of passes on nitrous and nothing has happened. I just launch at idle and don't really get on it till 2nd gear. my times are only 12.0's but I'm still trapping 125 plus. (stock tires)
if you feel wheel hop let off and you will be fine till you upgrade.
Old Mar 2, 2011 | 01:31 PM
Schoolteacher's Avatar
Schoolteacher
Ticking time bomb, sell it to an automatic guy and upgrade while you have a core... I wish I would have done that.
Old Mar 2, 2011 | 03:31 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I have the DTE brace. I don't expect it to make it bullet-proof but it has held up so far. Yes, the smart money says replace it with an '06+ diff, which also involves changing the tailhousing of the tranny as well. But I just can't bring myself to do it. If it does grenade my plan is to fab up an adapter to house a built C5 diff ala Sparo2. They are much cheaper.
PS: Wheel hop is a son'beach. I lost a short side output shaft to it when I had NAWS on my C5.
Old Mar 2, 2011 | 03:47 PM
cranky's Avatar
cranky
the bad part is............when your diff goes, so does the transmission main shaft usually. then you get to not only replace/upgrade the diff, you also get to repair the trans. BIG bucks. just got done upgrading the case and gear ration in my 05. guys at RPM TRANSMISSIONS are top notch. now i can make all the hp i want and go to the track with confidence of course, some people have to learn the hard way, don't be one of them...............
Old Mar 2, 2011 | 04:05 PM
Schoolteacher
Yup I bent my main shaft when my diff exploded and fell off. I wish I could go back in time...... If I had it to do over I would have sold the 05 diff and replaced it to save the tranny.
Old Mar 2, 2011 | 04:14 PM
stalker26's Avatar
stalker26
I agree with SCHOOLTEACHER replace before your upset like i was.... call RPM and talk to Jeremy or TJ both great guys and will work with you.
Old Mar 2, 2011 | 04:41 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I got 301 hard launches on the drag strip out of mine. Not 302. Case broke into pieces on 302. Pretty much no wheel hop out of mine, but that's a lot of drag strip passes so I'm not complaining.
Took out my tranny mainshaft too. I had a brace. When the diffs break they usually take out the trans.
You can swap to a c5 diff and sell your 3:42 diff to an automatic guy and not be much money out of pocket, and it's not a hard swap (contact Sparo2 or check his how-to). That's what I did and it's a great mod so far (131 passes so far, 1.49 to 1.5x's regularly).
If you don't go from a dead stop, my guess is you'll be fine. Seems that most guys who break them on the street do it wheel hopping so let out if you get any. I never get it even on the street but I don't race on the street either. Problem is, if it goes, it'll most likely take out the trans, and plan on about a $5k bill when that happens because you won't have a core.
Summary - depends on how you are going to drive. A few spirited runs now and then, it'll probably live a long time. If you race often, switch now and save a lot of money.
Old Mar 2, 2011 | 07:01 PM
saplumr's Avatar
saplumr
It's only a question of time on all of them if they have much power and it takes out the mainshaft. It happens when you least expect it! You have a core value until it breaks.
Old Mar 3, 2011 | 10:51 AM
Walt White Coupe's Avatar
Walt White Coupe
Judge for yourself.
Old Mar 3, 2011 | 10:52 AM
sevinn's Avatar
sevinn
Originally Posted by Walt White Coupe
Judge for yourself.
Wow that's quite a hefty difference.
To 05 differential, how bad are they?
Old Mar 3, 2011 | 11:51 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Here's what happens. I've seen several just like this. This one is mine.
Old Mar 3, 2011 | 11:53 AM
BT03mach-1's Avatar
BT03mach-1
air cooled!!!! it should work better!!!
Old Mar 3, 2011 | 10:20 PM
thebean's Avatar
thebean
After thinking it over I think my best bet is to skip the supercharger, leave the car stock and save for a Z06, that's what I was wanting to begin with. I figured by the time I spend $7,000 on a supercharger, $2,000+ on a new diff. and while it is apart a better clutch $1,000 then add in what I have in the car I would be withen $5,000 of a 2006/2007 Z06. Hopefully the diff. will last 1-2 years and if not I guess I made a bad choice.
