ls7 intake manifold swap ?'s
Swapping out my stock intake manifold/TB for a LPE ported TB/intake tomorrow. ALso putting a Killer Bee II on, any recommendations/tips?
Also, I really don't have to drain any coolant, do I?... the service manual says to...
Loctite (RED HIGH TEMP) all bolts! torque down bolts in crisscross pattern to correct torq.
Coolant drain not necessary,
Be careful with oil pressure sending unit behind the manifold..
Rear 2 bolts are a PITA, zip tie last 2 together (Keeps them up) allows manifold to come in/out freely.
Lube all injector o-rings when re-installing..
Things you will need:
Zip Ties, Fuel line disconnect tool, socket set, WD40, Loctite (RED),
