Anyone have weight reduction tips?
Old Mar 4, 2011 | 04:19 AM
cell6ida's Avatar
cell6ida
Default Anyone have weight reduction tips?
Can anyone share some weight reduction tips?
Thanks!
Old Mar 4, 2011 | 05:54 AM
Thrillhouse's Avatar
Thrillhouse
Go on a diet.
Old Mar 4, 2011 | 05:58 AM
timd38's Avatar
timd38
Lots of real carbon fiber and expensive wheels.
Old Mar 4, 2011 | 10:27 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
P90x
Old Mar 4, 2011 | 10:33 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Remove the Passenger seat (about 40-45 pounds and takes about 10-15 minutes)
Remove the front swaybar/brackets
Remove rear carpetting in the hatch
Remove mufflers/tips
Drain windshield fluid or remove the resevoir completely
Lightweight battery
Skinnies in front and lightweight wheels in the rear
Non runflat tires
Base rotors
Never have more than 1/2 tank of gas
Glass top instead of stock painted top
Take EVERYTHING unnecessary out of the car
Those are all easy weight reduction mods and will get you a couple hundred pounds lighter than the next guy.
Old Mar 4, 2011 | 03:51 PM
Sparo2's Avatar
Sparo2
If you don't plan on driving in the rain and know you'll never need them...remove the whipers and whiper motor assembley. Also, remove engine beauty covers, swap manifolds for headers, etc.
Here's a tip though... Removing 1lb from 10 different places is easier than removing 10lbs from 1 place. Removing a little weight here and some more there, it all adds up.
Old Mar 4, 2011 | 03:54 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
Great tips there. I assume you want a track car? Guess you could buy a Miata and throw a LS3 in it. LOL. Doubt it would fit.
Old Mar 4, 2011 | 08:21 PM
1fastbob's Avatar
1fastbob
http://www.flyinmiata.com/V8/green99/ LS2 LS3 will fit in a Miata, Check it out or better yet have them build one for you. http://www.flyinmiata.com/V8/configurator.php
Bob
Old Mar 5, 2011 | 02:50 PM
tomiboy's Avatar
tomiboy
2 piece rotors
Old Mar 5, 2011 | 04:20 PM
pbm.cc's Avatar
pbm.cc
My buddy is running his Miata with a LSX... Made it fit. On 205tires though! Lol
Old Mar 5, 2011 | 05:17 PM
smurfkiller's Avatar
smurfkiller
i have built 2 LS powered miatas. almost completely useless though,just smoke the tires. they fit easily monster miata make tons of parts for this and a complete 5.0 kit.
Old Mar 5, 2011 | 08:27 PM
SpryGeezer's Avatar
SpryGeezer
Remove both GM Chiclets.
Old Mar 5, 2011 | 09:36 PM
Gold Z's Avatar
Gold Z
Veteran: Marine Corps
Drive naked.......
Old Mar 5, 2011 | 09:56 PM
Streetfast's Avatar
Streetfast
Add 2 more pounds of boost. Keep the weight.
Old Mar 6, 2011 | 12:25 AM
5knives's Avatar
5knives
It depends how much you want to alter the car. Lowering rotational weight such as lighter wheels, tires, brakes, and a lightweight clutch/flywheel will probably make the most impact without losing any of the car's comforts. Although every little bit helps, everything else doesn't seem to do as much. It takes a lot if weight removal to improve performance and sometimes it's not worth it. But only you can make that decision.
Jmo
Old Mar 6, 2011 | 01:40 AM
Bill Dearborn's Avatar
Bill Dearborn
If you are looking for a track car then skinnies in the front would be a disaster. They don't turn well. To get the weight out of the car you should think about the following:
Dump the Carpet
Get rid of passenger seat
Replace Driver's seat with Sparco or similar unless you are installing a bar/cage then go with aluminum race seat
Pull AC/Heater and plug the firewall holes.
Pull interior panels off from doors, quarters, etc
Remove hood insulation
Remove headlights
Remove knee bolsters from dash pull glove box
Drill holes in every hinge flange (keeps strength but takes out weight)
Replace back glass with plexiglass
Take out the door windows and pull the mechanisims
Two piece rotors front and rear
Replace mufflers with straight pipe
CCW Classic wheels front and rear (won't fit wide body big brake cars)
Dump the run flats and go with Hoosier Tires (most of them are pretty light compared to other brands)
Probably some more things but I can't think of them now. Have seen most of those things done to a number of C5/C6 Race Cars.
Bill
Old Mar 6, 2011 | 09:11 PM
mountainbiker2's Avatar
mountainbiker2
Be very very careful. It's addicting. I started out with a few items, then next thing I know it looks like this.
C5 FRC. #2750
Steve A.
To Anyone have weight reduction tips?
Old Mar 6, 2011 | 10:19 PM
LEAVINU's Avatar
LEAVINU
Lots of different angles here but the OP never clarified what reason/purpose he wanted to drop weight. That defines how in depth the recommendations should be really.
Old Mar 6, 2011 | 10:44 PM
achilds's Avatar
achilds
Jenny Craig?
Old Mar 7, 2011 | 01:09 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
That's good advice.
A 2006 coupe has about 7.5 lb/hp. Removing 150 lbs, which is a major project that will effect the street usefulness of the car, will add the equivilant of about 20 hp. Getting another 20 hp from a blower, make it 25 hp to account for the blower weight, is pretty easy.
Weight has other disadvantages, but for an already-built car, adding hp is usually the way to go.
