NPP Exhaust Conversion
Old Mar 11, 2011 | 05:51 PM
sgd1201's Avatar
sgd1201
Default NPP Exhaust Conversion
What parts would be necessary to convert a 2010 GS coupe that was not ordered with the NPP dual mode exhaust, to be converted to the dual mode exhaust and work just as if it had been ordered that way from the factory?
Also if the factory parts were used and installed as mentioned above would they fall under the Warranty for the period the warranty is in effect?
Old Mar 11, 2011 | 06:16 PM
RicK T's Avatar
RicK T
You can't add the factory functionality after the fact. You can add the NPP mufflers with manual control or.......maybe Sunset Orange Creations has an add on controller that mimics the factory control, you'd have to talk to him about that. Here's some reading for you:
http://forums.corvetteforum.com/c6-c...t-bolt-on.html
Old Mar 11, 2011 | 06:22 PM
j_digi454's Avatar
j_digi454
Yes, SunsetOrangeCreations has many models including one that will open the exhaust valves based on rpm which is essentially what the factory system does. Click on the link below for more info.
http://sunsetorangecreations.com/Products.php
Old Mar 11, 2011 | 10:43 PM
sgd1201's Avatar
sgd1201
thanks guys!
Old Mar 12, 2011 | 11:42 AM
Lord Melbury's Avatar
Lord Melbury
Hi,
you can make the conversion to be quite near as if it had been ordered with NPP. The only difficult part is the electrical wiring and the control module but most likely you want to operate the flaps manually. I have done this conversion on my -08, I used NPP mufflers, vacuum solenoid, vacuum reservoir, vacuum pipes, all GM original parts. The fasteners in the tunnel for the pipe is already there, the pipe is installed togehter with the fuel lines. I used a control module from Sunsetorangecreations which operates the flaps from the dash DIC reset button. The total cost was almost the same as if I chosen B&B Fusions with retrofit vacuum and control kit (in swedish currency).
/Hakan
Old Mar 12, 2011 | 12:56 PM
MikeSVT04's Avatar
MikeSVT04
If you need 2009+ NPP exhaust (the piping is different for 2009+ vettes) let me know I will have a set in the next month of my 2010 GS.
Old Mar 28, 2011 | 05:49 PM
TXAtomic's Avatar
TXAtomic
I have a question this subject as well. I know that the 2009 and newer have different piping than my 2008 (non Z06). If I were to find the mufflers with matching X-pipe from an 09 or 10 GS, would I still run into fitment issues that require modification, or will this match up to my manifolds wihtout issue?
Old Mar 29, 2011 | 08:16 AM
TXAtomic's Avatar
TXAtomic
Think I found the answer to my post above. It is the design of the overaxle piping that is the issue, not sizing or x/h-pipe connections.
Old Mar 30, 2011 | 09:58 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
All you will need is the mufflers and the install kit. We can certainly help you out with that. Just send us an email or give us a call.
Old Apr 19, 2011 | 12:33 AM
StKnoWhere's Avatar
StKnoWhere
/Hakan
Are you saying there is an available line for the vacuum already available in the tunnel?
Old Dec 4, 2012 | 09:47 PM
usafwrench's Avatar
usafwrench
1st Gear
I have a 2009 C6 and I am stationed here in Germany. There are not a lot of Corvettes here, but there is a huge following. Does anyone know if the NPP exhaust is a direct replacement on the 2009 C6? Or will it have the same sizing issues as the 2008. Thanks!
Old Dec 5, 2012 | 11:04 AM
haljensen's Avatar
haljensen
2008 NPP mufllers and overaxle pipes will bolt in to any 2005 to 2008 C6.
2009 NPP mufflers and overaxle pipes will bolt on to 2009 and up C6's.
2009 NPP and overaxle pipes for a 2005 to 2008 C6 will require a 2009 or later mid pipe also.
Z06 Bi mode exhaust will not bolt on to any year C6, the Bi mode is larger diameter at the mid pipe and must be modified to fit by cutting/welding.
All add on NPP's will require a vacuum source and an exhaust control switch.
Old Dec 6, 2012 | 10:50 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
I was told by a few very wise vette guys including Kooks headers person that my 2002 6Speed Manual will use 2008 NPP non zo6 only w/ o any mod. If I use 2009+ I need to change the mid pipe accordingly. Non zo6 mids and zo6 mids with zo6 mufflers. 2009+ have auto and manual figment issues requiring modifying .
To NPP Exhaust Conversion
