injector help needed..
Old Mar 13, 2011 | 09:31 PM
kboboz71's Avatar
kboboz71
Default injector help needed..
While I was removing my injectors from my intake earlier, one of the plastic retainers on the end of one inj cracked and came off. My question is where can I get another one of these black plastic retainers to replace it. I have oem inj. That were redone to flow 65lbs at 3 bar. Any help is appreciated, I need it fixed by wed. That's when the new intake will b going on. Thanks.
Old Mar 14, 2011 | 07:02 AM
kboboz71's Avatar
kboboz71
Anyone???
Old Mar 14, 2011 | 07:04 AM
timd38's Avatar
timd38
May want to post a picture.
Old Mar 14, 2011 | 08:05 AM
kboboz71's Avatar
kboboz71
http://www.hinsonsupercars.com/Pics/...Comparison.jpg
Its the one in the middle. And its that small black retainer that is under the bottom o-ring it snaps over the metal lip towards the end of the nozzle
Old Mar 14, 2011 | 08:17 AM
timd38's Avatar
timd38
A used injector on Ebay?
Old Mar 14, 2011 | 10:50 AM
Stang's Bane's Avatar
Stang's Bane
Don't think you can buy just that part.
Old Mar 14, 2011 | 11:30 AM
kboboz71's Avatar
kboboz71
Is it a necessity?
Old Mar 14, 2011 | 06:07 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Call/Google Fuel Injection Connection they are in Cummings Ga
Old Mar 14, 2011 | 06:14 PM
SpinMonster's Avatar
SpinMonster
His injectors were stockers resized to 65's. I would think he needs to contact whoever resized them for a replacement. Its likely FICinjectors. No one else will know if there was a parts change outside the nozzle.
I doubt there will be a resolution to this outside a full replacement set if he cant find who resized them. Asking guys on a forum board is asking for best-guesses. If there is any issue, you are putting in one injector that will be different in size from the other 7.
My vote is to contact FICinjectors and see if this is their work. At the minimum they can match the replacement to the other 7 but I doubt its going to be under 100 bucks to flow check.
Old Mar 14, 2011 | 06:26 PM
kboboz71's Avatar
kboboz71
Im prob gonna put this one back on and use some plastic cement to hold it together. Its not a pressure point or a sealing point. Im sure it will b fine.
Old Mar 14, 2011 | 06:27 PM
kboboz71's Avatar
kboboz71
Plus its a clean crack on just one side so its still intact.
Old Mar 14, 2011 | 07:14 PM
glenB's Avatar
glenB
Sorry, meant Fuel Injector Connection
Old Mar 15, 2011 | 09:45 AM
JustCruzin's Avatar
JustCruzin
Should be fine. It's just a o-ring retainer, holds the o-ring on. Only thing is when and if you have to take it out again make sure the o-ring does'nt get stuck inside.
Old Mar 15, 2011 | 10:48 AM
kboboz71's Avatar
kboboz71
Thanks guys
To injector help needed..
