Service abs light on after pothole
Now my service abs light is on and the red brake light is on and won't go off when the E-brake is fully down. Anyone else have this happen? I'm going to bring the car to a friend to check the code and hopefully can get the new tire fixed under warranty as it has been way less than 30 days since I purchased them. The steering wheel is VERY tight now so obviously something isn't right. Hopefully it's just a sensor and the wheel isn't bent but again does anyone have any info on what may be wrong? Sorry for the double post, I just noticed the bubble on the tire not too long ago and used the search button but most of the info has come up on c5's and I can't pull any codes on the c6 without a reader...
Greg
Greg
There may be something you can do in the meantime though. On each wheel hub assembly is a connector for a vehicle speed sensor. I would suggest removing each wheel to make sure they're all still clipped on properly and to also disconnect and reconnect each one to reseat the electrical connection.
Not real good, but this is the only picture I could find.
1, 2, 3 and 4 actually point to the sensor assy's. The red arrows I added are the front connectors.
Greg
Lost Communications with XXX Control Module
IF,,,, the EBTCM lost comms with the BCM (for what ever reason) you would feel a tighter steering because of the MAGNASTEER in the steering box does not work without the EBTCM being fully operational. Completely normal!
I have not taken a C6 wheel speed sensor connector apart "YET" but, if there anything like the C5 connector, the female pins are often suspect.
The female pins can spread and deform under vibration / shock and will loose contact causing a loss of wheel speed sensor signal.
Here is an example of what a new and old (bad) wheel speed sensor femal connector looks like on a C5. The OLD one has deformed pins:
My guess is that you did have a wheel speed sensor issue and now the connection is good again. When you cycle the ignition, the EBTCM clears the DTCs and goes into a self test. If theres anything wrong during that ignition cycle, you will see messages. Read the DTCs prior to turning OFF the ignition to see what codes/DTCs caused the messages.
Bill
