Running higher temps
Old Mar 22, 2011 | 01:29 PM
VNVETT's Avatar
VNVETT
Default Running higher temps
Have an 07 Coupe weith a mild cam and it has never run over 185-190. Lately on the road I have noticed 220-230. Car runs fine but when I get home and shut down the cooling fans come on for a couple of minutes. Never did this before either. Any pointers on what to troubleshoot? Thanks VNVETT
Old Mar 22, 2011 | 02:41 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Im having a similar condition.
My guess is the coolant?
Old Mar 22, 2011 | 02:42 PM
JoesC5's Avatar
JoesC5
have you checked the radiator for Walmart plastic bags?
Old Mar 22, 2011 | 03:02 PM
VNVETT's Avatar
VNVETT
Yep, clean as a whistle up front. any more thoughts???
Old Mar 22, 2011 | 03:16 PM
Robls6's Avatar
Robls6
Just because the front of the radiator looks clean, doesn't mean that the radiator isn't partially blocked with debris. Use a hose and rinse from the engine side out through the radiator. You'll be surprised how much crap comes out of it.
Old Mar 22, 2011 | 03:43 PM
dochorsepower's Avatar
dochorsepower
It could be an old thermostat not opening properly.
Old Mar 22, 2011 | 04:44 PM
quick Ag's Avatar
quick Ag
I have an 05 with a mild cam, I had a similar problem a few months back and it turned out to be the thermostat.
Old Mar 22, 2011 | 04:48 PM
Boomer111's Avatar
Boomer111
Most likely thermostat.
Old Mar 22, 2011 | 05:11 PM
VNVETT's Avatar
VNVETT
Thanks folks, I 'll check it out. VNVETT
To Running higher temps
