LS2 Dyno Results
Old Mar 23, 2011 | 11:59 AM
DannyBoyC6's Avatar
DannyBoyC6
Default LS2 Dyno Results
Just got my car back yesterday from a cam / LT header / tune install. Here's the SAE dyno results on a Dynojet 248E. Seem about right to everyone? I didn't get a 'before' dyno, unfortunately.
See sig for mods.
Old Mar 23, 2011 | 12:31 PM
JayplaySS2's Avatar
JayplaySS2
It would be easier to copy/paste your mods here in the thread, just an idea to save time-
A 224/228 is a pretty small cam and you're still running the LS2 intake, seems about right to me.
Old Mar 23, 2011 | 12:39 PM
MARSC6's Avatar
MARSC6
It would have been about 345hp stock so that is a decent increase.
Old Mar 23, 2011 | 12:45 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Not bad.
Did you get an underdrive pulley installed at the same time?
Old Mar 23, 2011 | 01:56 PM
DannyBoyC6's Avatar
DannyBoyC6
Originally Posted by FloydSummerOf68
Not bad.
No, I didn't.
Old Mar 23, 2011 | 01:57 PM
DannyBoyC6's Avatar
DannyBoyC6
Sig should be just below the dyno image.
Old Mar 23, 2011 | 02:03 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Sounds right.
A FAST 92 would really boost torque and HP with no adverse affects.
Old Mar 23, 2011 | 02:06 PM
DannyBoyC6's Avatar
DannyBoyC6
Originally Posted by Mez
Sounds right.
In your opinion, did I gain anything with the ported stock IM?
What would you expect I could gain with the FAST 92/102?
Old Mar 23, 2011 | 02:35 PM
FloydSummerOf68
Without an underdrive pulley I'd say your numbers are just fine.
With the pulley you would've been over 430rwhp, and that's not bad for a pretty mild cam and stock ported intake.
I don't think you'd pick up much peak power with the FAST intake, but you'd probably pick up a lot in the midrange.
Old Mar 23, 2011 | 03:18 PM
Mez's Avatar
Mez
On my car, I got about 15 rwhp when I ported the stock intake. I gained another 15+ rwhp over that when I put on a ported FAST 92. You'll see a big gain in both torque under the curve and peak HP with the FAST. The stock LS2 intake manifolds don't seem to do very well when you start putting on mods like you and me.
Old Mar 23, 2011 | 04:32 PM
scarface9's Avatar
scarface9
Is this A6? hows the street manner of this cam and have you got any videos?
Old Mar 23, 2011 | 04:52 PM
FloydSummerOf68
His sig says it's a manual
Old Mar 23, 2011 | 05:03 PM
DannyBoyC6's Avatar
DannyBoyC6
It's very well-mannered at low speeds, no surging, etc. I let the clutch out from a complete stop with no throttle applied, and it smoothly took off just like stock.
The idle is intermittently fairly choppy, and surprisingly I do get a little side-to-side rocking (also intermittent). The rocking is annoying, so I hope I can get it tuned out somehow.
At 3K and up in the RPM range, it absolutely screams.
Old Mar 23, 2011 | 09:31 PM
Mez's Avatar
Mez
I bet your idle can be improved.
What is your idle RPM? Going to 750 - 800 rpm will do wonders. With my small cam, my idle is rock steady at 675 rpm. I sure if you have it bumped up a little it will be much improved.
Also, if your idle over/under speed spark tables are too aggressive, the idle can get into a rhythmic up/down cycle. I call it chasing its tail. On a small cam like this, you can back down the spark over/under speed tables in the lower rpm cells because its ok for it to wonder a little. Also, you can hit it harder (more timing) on the under speed table but not so hard on the over speed. This should keep it from going up/down in a rhythmic cycle.
Old Mar 25, 2011 | 09:48 AM
LS1AGN's Avatar
LS1AGN
8th Gear
For comparison my car has TS Lt's OR xpipe, SLP LM2 over the axle, Halltech cai, and Fow Tech cam 228/232 .600/.600 112. My numbers (Dynojet) corrected where 420/394. So it looks like we are in the norm.
Old Mar 25, 2011 | 02:00 PM
DannyBoyC6's Avatar
DannyBoyC6
Interesting. Thanks for the info. I'll probably need someone's help if I'm going to go into the spark / speed tables and mess with their tune. I don't wanna screw anything up and am a complete novice about tuning.
I'm not sure what the idle RPM is, it does seem to vary a bit. I have HPTuners, so I'll connect the laptop this weekend and see what the setpoint is. Stay tuned.
Old Mar 25, 2011 | 02:01 PM
DannyBoyC6's Avatar
DannyBoyC6
Cool. Thanks for the comparison.
To LS2 Dyno Results
