TPS does not update
Old Mar 23, 2011 | 04:36 PM
Bill Suttie's Avatar
Bill Suttie
Default TPS does not update
One of my tire pressure sensors shows a constant reading of 30 psi. The other three fluctuate normaly with temperature. The 30 psi agrees
with my tire gage. Any thoughts? Thanks
Old Mar 23, 2011 | 04:48 PM
RicK T's Avatar
RicK T
If there was a problem with the sensor or system you would get an "XXX" or Service Tire Monitor message.
If you want to verify that it's working just let a few pounds out (or add a few) and go for a short drive to see if it shows the new reading.
Old Mar 23, 2011 | 04:50 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Probably the sensor battery is getting weak. They start to do funny things as they get weak. You might get lucky by trying to re-synch it with the TIPS tool but you will probably end up replacing it. I just went through this.
Old Mar 23, 2011 | 04:51 PM
Bill Suttie
I have done as you suggested, prior to posting, there was no change to the DIC reading.
Old Mar 23, 2011 | 05:28 PM
BEZ06's Avatar
BEZ06
Hey Bill
I looked in your profile and saw you're in FL - but where???
If you're anywhere from Jacksonville to Melbourne to Orlando we should get together and I'll try zapping your sensors to reprogram them and see if that does any good.
My TPMS tool is a high-end one with a screen and will display the sensor's battery status.
PM me if you're any place in Central FL.
Bob
Old Mar 23, 2011 | 06:03 PM
Bill Suttie
Bob I'm at The Villages. I appreciate your offer but, I'll be at my dealership to change my coolant next week. I'll have them check it out. If you are over this way we have a rather large car show from 4 to 8 PM every third Saturday of the month. Cars have to be older than 1980. Again thanks for your offer.
To TPS does not update
