Lowering bolt install on rear?
Old Mar 23, 2011 | 09:11 PM
Rotorhead48U's Avatar
Rotorhead48U
Default Lowering bolt install on rear?
Tried installing the lowering bolt kit on the rear yesterday and ran into major issues with the placement of the half shaft and the lower ball joint nut/bolt...
Is there anybody out there who has personally installed this kit on the rear of a C6?
And if so, how the hell do you get clearance to remove the factory bolts?
The guys I it bought from have no idea... go figure...
Thanks in advance - Dubya
Old Mar 23, 2011 | 09:16 PM
timd38's Avatar
timd38
Drop the lower control arm. I will buy your old bolts.
If you live near Milwaukee come to my house and will help you do it, but your profile doesn't say were you live.
breecher_7's Avatar
breecher_7
You going back to stock Tim?
Old Mar 23, 2011 | 10:27 PM
marc8090's Avatar
marc8090
Do NOT remove any ball joints to try to get the lower A-arm low enough to get the lowering bolt out. Instead, disconnect the sway bar end link, upper shock mount, and UPPER A-arm at the frame. This combination will allow the lower A-arm with the knuckle and half shaft still attatched to drop low enough to get the bolt out. I did it this way after a search here and because I saw no convenient way to get a torque wrench on the nuts for the ball joints.
Old Mar 23, 2011 | 11:11 PM
Rotorhead48U
Thanks marc8090, I'll give it a shot, I couldn't believe how nothing is mentioned in the installation instructions about the rear... I guess the vendors all think we're 1st class mechanics
I live in the northern Idaho panhandle, if the bolts come out clean I will try and send them to the guy that asked for them...
Thanks again, hope it works
Old Mar 24, 2011 | 09:19 AM
TonyD22's Avatar
TonyD22
I installed mine myself and did exactly what MARC said.
Old Mar 24, 2011 | 12:06 PM
Rotorhead48U
Thanks Tony, glad to hear it worked for you too, i'll try it asap -
Old Mar 24, 2011 | 12:18 PM
Rotorhead48U
Hey guys, having trouble with spring contacting the drive shaft, and still not providing enough clearance to get the bolt... I must be doing something wrong?
Old Mar 24, 2011 | 01:43 PM
timd38's Avatar
timd38
No, I did bolts and then went to coilovers. I would like to have the stock bolt for when I do.
Thanks!
Old Mar 24, 2011 | 04:46 PM
Rotorhead48U
just wrapped it up, much appreciate the help, it worked effortlessly...
thanks again fellas - Joel
Old Apr 14, 2011 | 11:33 PM
IrishC6's Avatar
IrishC6
This is exactly the info I was looking for. I tried in my garage and had hell getting to the lower ball joint bolt. Would you happen to know the torque settings for the sway,shock and a-arm bolt?
Old Apr 15, 2011 | 07:22 PM
smurfkiller's Avatar
smurfkiller
Originally Posted by IrishC6
I Would you happen to know the torque settings for the sway,shock and a-arm bolt?
yes, those torgue specs are german good-n-tite. just makes sure every things nice and tight you dont have to go crazy and torgue it to 200ftlbs, just give it 2 grunts.
Old Apr 18, 2011 | 03:13 PM
marc8090's Avatar
marc8090
I'm moving in a couple days and my manuals are all packed up so I can't provide the torque specs at this time but hopefully somebody else can to help you out.
Old Apr 18, 2011 | 11:31 PM
BEZ06's Avatar
BEZ06
Torque specs can be found on forum member David Farmer's site:
http://davidfarmerstuff.com
Bob
To Lowering bolt install on rear?
