service charging system warning - VICTORY
Actually, I found a place down the street from my work-- I walked the starter in and they changed it out in about 2 min... thus the $15 was the installed price.... here is the shop -- I am sure if you contact them, they would be willing to help anyone out:
ACE Alternators & Starters
13201 Imperial Highway
Whittier, CA 90605
(562) 903-4150
Hard to believe but they are open 7 days a week !
There is also a second place that came highly recomended to me it is called :
AGS
969 Fairway Drive
Walnut, CA
(909) 468-1777
they specialize in hard to find parts and will rebuild while you wait.
edit -- if anyone needs a solenoid and they will not ship, contact me and I will help you out.
Whittier, CA 90605
(562) 903-4150
AGS
969 Fairway Drive
Walnut, CA
(909) 468-1777
PM Sent.
Reply sent -- You are not that far of a drive from me btw...
P.S. that is extremely common problem ( i.e. the melting ) ... I am experimenting with a heat shield from a Chevy truck to see if that will help .. it was a pain in the *** getting it to fit.. so I hope it works...
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The solenoid Bakelite insulation burns due to a poor connection on the battery terminal or the starter terminal. The HIGH CURRENT with a POOR CONNECTION, caused LOTS or heat.. It fries the Bakelite!
I have stainless works headers and NO shields and have ZERO burn issues. This connection MUST BE clean and tight and easily gets compromised. If you see charging system faults and fluctuating charging voltages,, thats the FIRST place to check!!
it was hard to start sometimes, but now it does not start at all (it only clicks once and no cranking at all). i think i found the problem in my car..
i found the part (inside the red circle) loose and looks like it's burned. what is the fix for that?
is there any way to start the car?
Uploaded with ImageShack.us
mine is not starting at all.
Google GM solenoid screwdriver trick and you will get lot's of information on the subject.
I can tell by the purple wire in the picture that is the starter solenoid.
The good news it is an easy fix ... just a matter of dropping the starter and replacing the solenoid -- the bad news is you will not be able to start your vehicle because of that solenoid's design.
The total cost of this fix if you do it yourself is under $20.
If you are in So Cal, I can help you get it done in under an hour.. just need to bring over my low rise jack, jacking pucks and a few tools.... and you will be back on the road in no time .
do i need to replace the solenoid? dealer won't sell the solenoid alone, i already asked them.
You are getting the same line of Bull Sh@t I was given by the dealer. Sure they want you to replace the starter as it is a higher profit generating item -- likely they are going to charge you about $700 - $800 ... hell, for that money I will drive to you and fix it. Seriously, if you have trouble finding a place, I will personally stop off at my local shop and see if I can pick you up one...
But you can save a lot of time and hassle by just finding a local alternator/starter shop in your area... and to answer your question -- YES you in fact need a new soleniod and that is the cause of your problem. I am 99.9% sure.
I would definately go with the "cheap fix" first as the soleniod is only about $20.00 ---
Bottom line is this, the corvette is a very well designed vehicle and from my experience, very easy to work on. Do not be afraid to fix it yourself, if you need help there are plenty of us here to guide you through it ...
#35
But you can save a lot of time and hassle by just finding a local lternator/starter shop in your area... and to answer your question -- YES you in fact need a new soleniod and that is the cause of your problem. I am 99.9% sure.
#37
Does anyone know the size of the teeny tiny screw heads to remove the selenoid screws? I cannot pull my starter all the way out because of the turbo/manifold is in the way (which is a big pia to separate). I am able to rotate the starter around enough to get to the screws. I just need to know what tool to purchase?
#38
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill
#40
