FNG question
Old Mar 25, 2011 | 03:45 PM
ReosLS2's Avatar
ReosLS2
Default FNG question
Hello
Newer Guy to forum.I am planing to install ARH headers on my corvette and understand from others posts that this will cause the car to run rich.Well the shop I'm going to , to have it tuned afterwards is 35 miles away.Is the car running rich going to lead to Bore Wash in the cylinders which might be bad for the rings etc. or will it be alright for the 35 miles if I take it easy ?thankyou...
Old Mar 25, 2011 | 03:55 PM
Sparo2's Avatar
Sparo2
Actually it might make it run lean instead of rich. But in any case, you'll be fine. A tune will maximize the power your headers can give. If anything, you might end up throwing lean codes (or inefficient cats if you're going catless).
Bottom line, install the headers and don't worry about it. You won't hurt anything. Just drive it up there and get it tuned.
TIP: Don't forget to remove the spark plugs first or you'll risk cracking a plug.
Old Mar 25, 2011 | 04:12 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
youll be fine.
Old Mar 25, 2011 | 04:42 PM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
+1, had mine on without a tune for a month. No worries at all.
Old Mar 25, 2011 | 05:53 PM
ReosLS2's Avatar
ReosLS2
Appreciate the replies...they're going on.
Old Mar 25, 2011 | 06:00 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
You should get a tune but driving without one won't do ANY harm. You just won't get the full performance effect without the tune.
To FNG question
