Spark plugs recommendation
Old Mar 28, 2011 | 09:28 AM
rocky7corv's Avatar
rocky7corv
Default Spark plugs recommendation
I installed a Maggie TVS 2300 on my C6 LS2 .. It runs great however, I seem to be burning way to much gas ...I had it tuned and it still seems to burn more gas a simular set-up's ... Can my spark plugs, which are stock, be a problems?
Old Mar 28, 2011 | 10:02 AM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
I don't think that's your issue.
Old Mar 28, 2011 | 10:50 AM
NYC6's Avatar
NYC6
#1- why are you still on stock plugs? A cooler plug is used for FI cars. Most use NGK TR6.
#2- FI cars burn more fuel, get used to it.
What are your mileage #'s?
Old Mar 28, 2011 | 11:54 AM
csun213's Avatar
csun213
and I used NGK TR6 with my Vortech however Edlebrock E-Force recommend that you stay with the stock spark plug (Not sure why)
Old Mar 28, 2011 | 12:17 PM
NYC6's Avatar
NYC6
Thanks for the correction.
Wonder why though?
Old Mar 28, 2011 | 01:07 PM
kboboz71's Avatar
kboboz71
Ngk br7ef plugs are optimum for boosted motors. Most people call them tr7s.
Old Mar 28, 2011 | 01:22 PM
rocky7corv's Avatar
rocky7corv
On a normal cruise run ... I used to get 22-24 pushing it a times ... Now ... not even playing I get 18-21 if I'm lucky .... I'm running wider tires all around .. 285 front and 345 rear. I know the drag of the tire have some effect. Even thou it was turned at England Green and corrected for fuel/air mixture, at times the cars behind me can smell the fumes. I cam also smell it when stopped. There are no leaks!!!
Old Mar 28, 2011 | 05:11 PM
Bill Dearborn's Avatar
Bill Dearborn
The tires can have quite a bit to do with the gas consumption. Even with the same size tires. For example, with my C5Z I had a set of stock wheels with stock S/C tires on them and also a set of stock wheels with Firestone Wide Ovals on them. When I had the WOs on the car it would get 2 miles to the gallon less fuel mileage every time. I saw this multiple times and the change was always the same. The Firestones were softer tires and had more rolling resistance.
Bill
Old Mar 29, 2011 | 08:49 AM
NormWild's Avatar
NormWild
From experience ditch the Irridiums, we have had all kinds of tuning issues on several cars with F/I. That thin electrode gets extremely hot and causes detonation, plus the heat range of the plug is incorrect for boost. The most common plug for boost on stock compression is NGK TR6 gapped at .035. They are copper, I change mine out ever 10-15K.
Old Mar 30, 2011 | 09:57 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
how much boost you run also should be a factor and how much hp your making.. I run a br7ef and I am n/a
Old Mar 30, 2011 | 10:11 AM
kboboz71's Avatar
kboboz71
He's right. Up to 10lbs id say tr6 are fine. But anymore than that I would run the colder 7 plug. Its also gapped tighter and eliminates spark blowout under high boost
Old Mar 30, 2011 | 12:51 PM
JoesC5's Avatar
JoesC5
Friend who installed a Maggie, mild cam, long tubes and a conservative tune(for 91 octane) gets 20-22 MPG when on the highway with his 2010 GS coupe/manual trans. That's cruising, not hot rodding. That's hand calculated as you can't go by the DIC as the injectors were changed for larger ones. Seems most GS owners on this forum report that they only get around 24-25 MPG with their stock Grand Sports, he lost around 4 MPG with his MODs.
Old Mar 30, 2011 | 12:53 PM
JoesC5's Avatar
JoesC5
Bill
I agree. On my C5 when I changed from the OEM Goodyears to Michelin A/S tires I lost about 2 MPG. I just installed Bridgestone's on my Z06 and I'll see shortly how they affect my gas mileage.
Tire alignment also affects gas mileage. Toe being off can cause a lot of tire scrubbing.
Old Mar 30, 2011 | 02:49 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Smelling raw fuel is not normal. Need to check that out to make sure there are no leaks and if your LTFT% error is in the normal range.
Old Apr 1, 2011 | 09:30 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
are you running cats? i am catless and NA,i can smell fuel as well when stopped (the cars behind im sure can too), ecs tuned it and says running w/o cats will do that
To Spark plugs recommendation
