Trunk Button not working
Old Mar 29, 2011 | 10:43 AM
cgeaves's Avatar
cgeaves
Default Trunk Button not working
All of a sudden this morning my trunk button above the license plate on my 2006 C6 Z06 is not working. I use it all the time instead of pulling my key out...very convenient. The trunk button on my remote works perfectly as does the button on the dash inside the car. I'm assuming there is a problem with that switch and I just need to disassemble and see what is going on. Anyone have this problem before?
Old Mar 29, 2011 | 10:51 AM
lockman's Avatar
lockman
I have read that if you take the rubber cover off of it and clean it out that works sometimes guess dirt gets in there sometimes
Old Mar 29, 2011 | 11:17 AM
DaBullish1's Avatar
DaBullish1
Do a search. Some one documented the step by step procedure for cleaning the dirt/corrosion that can affect the contacts on the switch.
Here you go.
http://forums.corvetteforum.com/c6-c...-pictures.html
Last edited by DaBullish1; Mar 29, 2011 at 11:22 AM. Reason: Provide link to information needed by op
Old Mar 29, 2011 | 11:49 AM
cgeaves's Avatar
cgeaves
Thanks DaBullish1
Old Mar 29, 2011 | 11:56 AM
Schoolteacher's Avatar
Schoolteacher
I cleaned mine out just the other day using the Talon writeup. I put a little dielectrical grease in there to help. It works great now.
Old Mar 29, 2011 | 12:29 PM
EVRose's Avatar
EVRose
Same here. You'll be surprised that even with the rubber cover on it how much dirt gets in there and jams everything up.
Old Mar 29, 2011 | 12:32 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
I bought a new one from Gene Cully at www.gmpartshouse.com cost less than $20.
Old Mar 29, 2011 | 02:50 PM
cgeaves's Avatar
cgeaves
Just to report I followed the instructions in the thread referenced and that did the trick. There was very little dirt in there but I cleaned it out with a q-tip, put it back together and it works like a champ. Thanks everyone!
To Trunk Button not working
