Transmission/Clutch problem
Old Apr 4, 2011 | 01:08 PM
TY'Z Vette's Avatar
TY'Z Vette
Default Transmission/Clutch problem
I have a bad driveline shake...
I first noticed it when in traffic. I would leave the car in first and bring it up to about 20MPH then decelerate down to about 15MPH and get a horrible driveline shake like the clutch is not fully disengaged....
So I am wondering if this could be a bad slave cylinder, or clucth? I bought the car with abot 12K miles and it was owned by an older lady...maybe she burned the clutch out?
My car is a 2005 MN6 it has 30K
Thanks in advance,
Old Jun 27, 2011 | 01:33 PM
TY'Z Vette's Avatar
TY'Z Vette
HELP
Old Jun 27, 2011 | 03:30 PM
Sparo2's Avatar
Sparo2
I'm trying to imagine what you're experiencing. Is your clutch slipping? Put it in 2nd and around 4K rpms give it WOT. It you see the revs jump without the car increasing much speed then your clutch is shot.
If you're drivetrain is shaking under acceleration and decceleration then your motor mounts and/or transmission/diff mounts are probably shot. When you accelerate does your shifter move a lot? If so then that could be your problem.
Old Jun 27, 2011 | 04:09 PM
TY'Z Vette's Avatar
TY'Z Vette
Its with the trany in 1st gear position accelerating to 20MPH then pushing the clutch in and coasting to about 15MPH then the whole driveline starts to shake.
To Transmission/Clutch problem
