Tire pressure - non-runflats ?
Old Apr 8, 2011 | 02:41 PM
DrewN209's Avatar
DrewN209
Default Tire pressure - non-runflats ?
Just had some Conti extremecontact DW tires installed this morning. OE sizes... what cold tire pressure is everyone running on their non-runflat set ups ? I am assumming the 30 I ran on the F1's will not be ideal do to the much softer side wall ?
And by the way... as everyone on the forum preaches, the difference in ride quality and especially nosie reduction is nothing short of spectacular.
Thanks.
Old Apr 8, 2011 | 04:40 PM
TLK's Avatar
TLK
St. Jude Donor '09-'11
Short answer: same size tires then same pressures.
Old Apr 9, 2011 | 07:00 PM
DrewN209's Avatar
DrewN209
Thanks.
Any links or places you recommend I read up on this ? Not doubting you, just looking to get educated.
Old Apr 9, 2011 | 07:06 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I run my 305 non runflats at 28 cold...get to about 33 hot.
Old Apr 10, 2011 | 12:10 AM
Like dem Vettes's Avatar
Like dem Vettes
You should use the pressure recommended in the owner's manual (no more, no less for daily driving). These pressures are always for cold tires (i.e., the car is not moved for three hours).
Old Apr 10, 2011 | 12:12 AM
TLK's Avatar
TLK
There are some posts (I don't have links to) that describe how the stock tire pressure is calculated based on the vehicle weight distributed to the four corners, contact patch size and maybe something about the sidewall (I'm not sure about that one). Assuming the tire dimensions are approximately the same as stock, then the cold tire pressure would be the same.
My guess on the subject is that if radically different size tires are used that have different contact patch size, the equivalent cold tire pressure would be different.
Old Apr 10, 2011 | 01:31 PM
goatts's Avatar
goatts
Thanks.
The difference you see is because you replaced an old set of wornout tires with new ones. Has nothing to do with runflat vs non runflat. Tire pressure is the same for both.
Only advantage of non runflats is price.
Old Apr 10, 2011 | 02:06 PM
Walt White Coupe's Avatar
Walt White Coupe
Now there is an uniformed opinion.
Old Apr 10, 2011 | 02:25 PM
goatts's Avatar
goatts
Actually it's an opinion based on facts. List some advantages other than price and give us some facts/data to back it up. Don't give us baseless opinions and seat of the pants bs.
Old Apr 10, 2011 | 02:49 PM
FloydSummerOf68
....amazing
Without even talking about measureable performance stats the advantages are already price, road noise and weight
Old Apr 10, 2011 | 03:20 PM
Boomer111's Avatar
Boomer111
Originally Posted by FloydSummerOf68
....amazing
And do not forget ride quality.
Old Apr 10, 2011 | 03:46 PM
cthusker's Avatar
cthusker
....amazing
I found a HUGE reduction in road noise level and elimination of bump steering when switching from GY's to non run flats..
Old Apr 10, 2011 | 06:11 PM
Walt White Coupe
Come on guys those are just "baseless opinions and seat of the pants bs"
Old Apr 10, 2011 | 07:42 PM
goatts's Avatar
goatts
....amazing
Yes, amazing. Road noise is a myth. Corvette Fever did a study measuring decibel levels between runflats and non runflats and there was no significant difference. There is no significant difference in weight.
http://www.corvettefever.com/techart...son/index.html
Old Apr 10, 2011 | 07:45 PM
goatts's Avatar
goatts
This is typical. No specifics. Why would the ride quality be better? Don't tell me it's because the sidewalls are thicker because they're not.
Old Apr 10, 2011 | 07:46 PM
goatts's Avatar
goatts
See my post #14. Don't know about "bump steering" but if you like to race I can tell you they don't handle any better.
Old Apr 10, 2011 | 07:48 PM
goatts's Avatar
goatts
That's exactly what they are. Why do you think they're better, smart guy?
To Tire pressure - non-runflats ?
Old Apr 10, 2011 | 07:59 PM
goatts's Avatar
goatts
Because I'm a smart guy and apparently you're not.
I added a link to the article on tire noise if you're interested. I'm still waiting for a post from you that contains something other than hot air. Once again, why are they better?
Old Apr 10, 2011 | 08:16 PM
cthusker's Avatar
cthusker
I'd like to see the same test run when both type of tires when they had 15 or 20k miles on them....
It was an interesting article...
Old Apr 11, 2011 | 01:01 AM
Walt White Coupe
Let me step back. I think the reality is that there is a wide range of tire performance characteristics and there is now a wide range run flat tire options. And there are some run flats that will perform better than non run flats. It depends on the tire brand and the performance characteristic you are talking about.
