Top 10 things to do with a Tech II
Old Apr 8, 2011 | 09:12 PM
KOZ's Avatar
KOZ
Default Top 10 things to do with a Tech II
Just got this a few weeks ago. What are the Top 10 things I can do with it?
1. Bleed the ABS circuits in the brake system. - BEZ06
2. program extra fobs - Loaded08
Old Apr 8, 2011 | 09:18 PM
BEZ06's Avatar
BEZ06
1. Bleed the ABS circuits in the brake system. Without a Tech II, when you bleed the brakes, you can't open the valves to flush/bleed the entire brake system.
Bob
Old Apr 8, 2011 | 09:51 PM
Loaded08's Avatar
Loaded08
Not too exciting, but I believe you can program extra fobs with it.
Old Apr 9, 2011 | 12:15 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Mate factory radios with new vehicles.
Old Apr 9, 2011 | 12:26 AM
StKnoWhere's Avatar
StKnoWhere
Make friends at the Corvette club
Old Apr 9, 2011 | 12:39 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
You don't need a Tech II to do this.
Old Apr 9, 2011 | 07:04 AM
fred_S's Avatar
fred_S
You do need a Tech 2 for the EU cars
Old Apr 9, 2011 | 08:14 AM
LEAVINU's Avatar
LEAVINU
Program TPMS?
I know their are other options to program these but I'd assume the TechII can do it as well. Not sure, just throwing that out there.
Old Apr 9, 2011 | 12:05 PM
Kenny94945's Avatar
Kenny94945
Set the Air conditioning "after blow" set up to reduce AC odor occurance.
Old Apr 9, 2011 | 12:11 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Transmission Fast adapt learn procedure
TCC slip data
Solenoid purge clean process
BCM set-up add options (automatic trans,hud,etc...)
Old Apr 9, 2011 | 12:30 PM
Bill Dearborn's Avatar
Bill Dearborn
When doing diagnostics it can be used to command certain functions to operate in a test mode while monitoring their performance to see if they work properly.
This is one of the most important features.
Bill
Old Apr 14, 2011 | 06:06 PM
Loaded08's Avatar
Loaded08
My ex had a Saturn VUE. Her [broken] fob was only for unlocking doors, panic, hatch pop, etc. I believe the TII is required to program the fobs for let's say, "some GM vehicles."
Old Apr 14, 2011 | 06:36 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
trick a non xm car into thinking its an xm equipped car to pick up the peripheral pxamg ipod interface on the xm channels
To Top 10 things to do with a Tech II
