wheel offset issue
Old Apr 12, 2011 | 11:40 AM
youout's Avatar
youout
Default wheel offset issue
For use at the drag strip I am planning on using a C5 Z06 wheel. It is an 18 x 10.5 inch with a +55mm offset. The stock wheel , as you know, is a 19 inch wheel with a +65mm offset. The tire I am planning on using is a Nitto NT 05R P285/40R 18. The wheel diameter of the 18 inch Nitto is almost identical to the 19 inch stock PS2 tire.
What problems will I have with the offset difference? If any can it be fixed with a 10MM wheel spacer? How complex a job is it to use a wheel spacer/ Are new studs required? Is the spacer permanent? If so that would make my offset +75mm with the PS2’s.
What about any other issues you guys might know from experience.
I want to be able to take off the Stock PS2’s and put these tires on and run at the strip. Then take them off afterwards and back on the street with the PS2’s.
Old Apr 12, 2011 | 12:08 PM
RicK T's Avatar
RicK T
No personal experience and not an expert, just passing on what I've seen here. Hope it helps.
I put links to 2 other threads in this one:
http://forums.corvetteforum.com/c6-t...n-base-c6.html
Old Apr 12, 2011 | 12:49 PM
LS1LT1's Avatar
LS1LT1
Actually they're +79mm.
The base C5 LS1 18" rear wheels are +65mm.
Old Apr 12, 2011 | 01:17 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Are you sure that C5 Z06 rear wheel that you want to use at the drag strip has a +55mm offset? ... From what I have read, if it's OEM, it is a 18" x 10.5" with a 58mm offset.
Also, are you sure that your stock C6 2006+ Z06 rear wheel has a +65mm offset? ... I can tell you, if it's OEM, it is a 19" x 12" with a 59mm offset (same as the 2010-2011 Grand Sport)
Lets say the offsets I just gave you are correct. If you remove the your stock 12" C6 Z06 wheel and replace it with the 10.5" C5 Z06 wheel, the C5 wheel's inner edge will move inward 20mm (0.8").
The outer edge of the wheel will move inward 18mm (0.7").
Calculator: http://www.1010tires.com/wheeloffsetcalculator.asp
Old Apr 12, 2011 | 08:38 PM
youout's Avatar
youout
you are correct they are offset of +58mm. I have a C6 ( not Z06) and i thought the offset was +65mm. It seesm from what I am reading that using a C5 Z06 18 inch rim on the rear of my C6 will work but i may need an 8-10 mm shim.
Then the question is will the stock wheel studs work fine if I shim 8 mm? Are they long enough?
Old Apr 12, 2011 | 09:09 PM
dbratten's Avatar
dbratten
The 18x10.5 wheel will stick out an inch more than the OEM 19x10" wheel that you now have. There is no problem with clearance to the inside. You will not want to move it out more with spacers.
What is normally done to run drag tires is to widen a 18x8.5 front wheel by 2-2.5 inches which will fit very well. A search will find many threads on this.
You can also take a 17" wheel and widen it (Weldcraft is one shop) in the same way. I run 17x9.5" + 2" wheels on the rear of mine -- all under the fenders. This may give you a better selection of tires.
Old Apr 12, 2011 | 09:26 PM
youout's Avatar
youout
Default details
Thanks this kind of detail is very helpful. I have found Nitto NT05R that are 285/40R 18 which work well on a 10.5 rim. I do feel that I have an inch width to work with but was not sure how much flex the tires goes through at the start. so i think this tire and rim combo should work. I race about once or twice per month
What advantage do I have having special rims made? I realy want to avoid spending a lot of $$ since this is not a regular thing.
Old Apr 12, 2011 | 09:49 PM
dennis50nj's Avatar
dennis50nj
use the base c5 rim, or find a 65mm 9.5 x18x65mm aftermarket c6 rim
Old Apr 13, 2011 | 06:25 AM
youout's Avatar
youout
Default Tpms
When you say base I assume you mean a stock C5 rim, right? Also will the C6 tire senor fit in a C5 rim? Are they are same size? This is all new territory for me.
Old Apr 13, 2011 | 04:11 PM
dbratten's Avatar
dbratten
I can't help you with drag setups as I only run autox and HPDE with Kumho 710 335x35x17" on the rear. You can look into reproduction wheels which are fairly cheap and have them widened (to the rear only.)
Old Apr 13, 2011 | 06:20 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
The base c5 18" rim works fine, even fits a 305 tire perfectly. I've used it on the road course.
A better choice is a c5 front or a c5z front with 275/40/17's, they are shorter tires and give you more gearing off the line.
However, if you have an automatic, you need to keep your tire size close to stock or you'll run into shifting and redline issues.
Old Apr 14, 2011 | 01:33 AM
HOXXOH's Avatar
HOXXOH
regarding the tire size. A MT or Hoosier DR will easily hold 500HP. However, the only problem I'd see would be when running a 2.73 gear and needing to shift to 4th with not much space left at the end. According to the OP's profile, he's a 3.15 gear, so the 4th gear shift would only be a problem with larger tires, not smaller ones.
Old Apr 14, 2011 | 08:53 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Tom did you have to adjust your shift points when going to the 275-17 tire?
To wheel offset issue
