how to access gas door cable?
my gas door release cable(spring) is not working. looked in the trunk behind carpet and cant get to it....do i need to remove rear fender well to get to it?
Yes.
Here's a thread with about everything you should need. Member Facade posted a link to a pdf DIY R&R that should get you through it.
http://forums.corvetteforum.com/c6-t...se-sticks.html
It is a very simple device. Basically it is a spring and a metal bullet shaped piece in a tube with the cable attached to the point of the "bullet". When you push the button it turns on a magnet that pulls the "bullet" back, pulling the cable and releasing the door. Move your finger off the button and the spring pushes it back. Try a little squirt of WD-40 where the cable goes into the module above the fenderwell inside your car and another on the release button inside the gas door.
