column lock not locking - bad?
Old Apr 16, 2011 | 07:44 PM
Red86Cfour's Avatar
Red86Cfour
Default column lock not locking - bad?
A few days ago I noticed that when shutting off the car (and shifting the trans to reverse - its an 05) that the steering column isn't being locked. When I start the car the buzz of the column lock actuator is silent. I've had my share of service column lock messages on the DIC with the car not starting, and even had the CLA replaced by the dealer that didn't solve the problem. I'm wondering if the column not being locked is a good thing? Should I leave it alone?
Old Apr 16, 2011 | 08:11 PM
Paratrooper307's Avatar
Paratrooper307
If the BCM doesn't get the right signal from the column lock module, your car will not start. I'd take it back and make the dealer fix it. The actuator not moving could be a prelude to the module failing altogether.
Old Apr 17, 2011 | 02:30 AM
Red86Cfour's Avatar
Red86Cfour
It took me three rounds at the dealer before they replaced the actuator. It took about two months on the new actuator before the SCL messages returned and the car would not start without multiple attempts again. Most of the time it starts with no problems, but every now and then it still happens. Zero confidence with the dealers service department.
The car still starts fine despite the lack of column lock actuation, so the BCM is getting some kind of signal to start. But I hear what you're saying. Could be just a matter of time.
Old May 22, 2011 | 02:59 PM
Red86Cfour's Avatar
Red86Cfour
Default another month
has gone by without a hiccup in starting the car. It sits for 3 plus days at a time and no issues with starting. The column lock continues to stay silent, and it starts right up immediately.
Old May 23, 2011 | 05:04 PM
vette6500's Avatar
vette6500
if i remember correctly, i believe mine went silent sometimes before eventually failing repeatedly to start the car.
when the dealer replaced the actuator, you should have instantly felt/heard the difference in the "zing" when the motor works.
mine was replaced 1.5 years ago and it's been working fine since, although the motor's zing is probably not as strong as it was when first replaced.
mine is a daily driver with multiple start ups made during a day, so at the rate you are starting the car, if you had your actuator replaced within the last 3 years, i would think it should not be failing again already.
i am suspecting for your scenario of non-use, it may actually be a dying battery. when was the last time you changed your battery? my car seems to go through autozone battery in ~2 years (luckily first time it was before 2 years so got a free replacement battery. then had to pay prorated for the next one after less than 2 years on that)
Old Jun 10, 2011 | 11:47 PM
ao22087's Avatar
ao22087
Default steering column lock possible fix
I have a 05 man trans corvette that just had the steering column lock replaced 5 months ago and it failed again already. So I took my old steering column lock apart and its just a electric motor that fails to move the lock pin in and out. There is a little switch(button) inside the scl housing that needs to be pressed in order for the car to start. The steering needs to be in the unlock mode in order for the pin to push the switch. I just remove the lock pin from the scl completly and glued a piece of plastic holding the switch down. The car starts right up and runs good so far. Ill keep everyone posted on if I run into any problems. Hopefully this is the bypass that everybody has been looking for. Keep in mind my steering will no longer lock though.
Old Jun 11, 2011 | 12:44 AM
Hoonose's Avatar
Hoonose
If your situation starts an episode of DBS, the battery will die in 24-48 hrs depending on your battery strength, since it drains at about a 1 amp/Hr rate. So on day #3 after shutting down, if the little red light is still flashing near your radio, you're good to go for at least few weeks without a dead battery.
Old Jun 11, 2011 | 06:15 PM
vette6500's Avatar
vette6500
sounds interesting. now if i can find the old scl that the dealer gave me, i can study your fix with visual aid. so the switch that needs to be kept down to start is located behind the locking pin i guess (when the pin unlocks/retracts, it goes in and presses down that switch)?
please update if you have any issues later with your fix, because it sounds promising.
steering not locking shouldn't be a problem, i thought 2006+ doesn't have the steering column lock at all.
Old Jun 12, 2011 | 12:00 AM
ao22087's Avatar
ao22087
Default steering column fix
yes, if you take apart that stl you will see a little button that the lock pin pushes in when unlocked. Its been 2 days now and over 100 miles on the car and everything seems to be working perfect. I am afraid that the battery could go dead though because of the fact that the bcm is not recieving signal that the steering column is locked. So ill keep everybody posted on it for sure every couple days. If everything is still good after a week ill post pictures and directions on what I did.
Old Jun 12, 2011 | 12:32 AM
Hoonose's Avatar
Hoonose
A way to check and see if DBS is pending is to go back from reverse to neutral before exiting the car. If you get the DIC warning to shift to reverse, then you've just headed off a DBS episode.
Old Jun 13, 2011 | 10:47 AM
dragonfly's Avatar
dragonfly
I have an 05 manual C6 as well. My issue is with the non-start as well. Replaced the battery about 2 months ago when it first stranded me. I do not get any error messages related to it, car just will not start. I do hear a buzz/humm like it is trying to unlock the steering column which is not locked. I have gotten in the practice of tugging on the steering column each time I exit to ensure it locks. Last night I got a book out of the car and it probably unlocked the column but new got it relocked......
If there is a way to overide the column lock I am all ears. I have had my hush panel off the steering column for about 3 months and have not seen the SAHS codes since(they were there just about daily before removing the panel). If someone can show a picture of the part being removed relative to the other components it would helpful.
thanks,
Old Jun 13, 2011 | 10:50 AM
dragonfly's Avatar
dragonfly
Oh yes, my short cut to keep from being stranded is to carry a ratchet. Disconnect the battery.....wait 3 minutes, reconnect and it starts like normal.
Old Jun 13, 2011 | 07:33 PM
vetsvett's Avatar
vetsvett
I dont think its the dealer. I believe it's GM not finding a solution, a permenant one.
Dragonfly, you may be able to either remove it or disable it just like on the C5's (can't remember which) maybe removed. Dealers wont remove it though because it's considered part of anti theft device.
Old Jun 17, 2011 | 12:18 AM
ao22087's Avatar
ao22087
well, so far what i did is working without any problems. Im gonna scan it with a tech 2 tomorrow to see if any codes have been thrown.
Old Jun 17, 2011 | 12:49 AM
vette6500's Avatar
vette6500
awesome, i'll have to study the old scl part more carefully to learn.
i assume u just disassemble the back/plastic area and get at the pin from that back side?
Old Jul 1, 2011 | 10:37 PM
ao22087's Avatar
ao22087
Default update
so its been a couple weeks now since I modded my steering column lock and everything is perfect. Havent had any problems at all. Ive scanned it with a tech 2 and everything checked out good.
Old Jul 14, 2011 | 07:19 PM
xgto's Avatar
xgto
Did you have to remove the steering wheel to do this bypass ? I would love to do this to my 05.
To column lock not locking - bad?
Old Jul 14, 2011 | 08:00 PM
ao22087's Avatar
ao22087
yes you have to remove the airbag, steering wheel, steering column plastic, lower kick panel under steering column, plastic around gauge cluster, and the gauge cluster. reason for all that is the wire attached to the scl goes all the way up and behind the gauge cluster on the right side. you do need a steering wheel remover set. you can get one at harbor freight that will do the job for around 40 bucks. It does take a while to do and it all fits together like a puzzle so take pictures if you have to for when you piece it back together. btw...my car is still working perfect since I did it so it does work if that is whats wrong with yours!
Old Jul 14, 2011 | 08:56 PM
srtrich's Avatar
srtrich
i really hope this is the fix as of lately everything on my 05 has been starting to go lol. plus sounds like it wont hurt my pocket.
Old Jul 14, 2011 | 11:21 PM
ao22087's Avatar
ao22087
yeah im not having the greatest luck either...battery needed replaced in the spring, both window motors broke($350 a piece my cost I work for gm), the scl problem, both door handle touch pads, and now my a/c compressor just went to hell...about to spend another $400 on that.
