it workrd last week but my wife used the key in the back to open the trunk now it wont open using the key fob,locks work remote ok ,,,,,whats th deal,,,thanks tony by the way the corvette is for sale right there for 25k
Reason: cause
My fob/car communication goes blank all the time. I park it...go to work...come out 10hrs later and doors/trunk wont unlock with fob. No light blink or anything. I have to pull the door open manually to re-initiate the fob talking to the car. Then its okay.
i have two remotes,,the lights flash when i press trunk but on clik or open,also i press the manual release on dash and nothing ,power locks work...anybody?
Sounds like either the tonneau for the top isn't fully closed with the top up (most likely) or the switch that says it's closed is broken or fell out of adjustment.
You can't open the tonneau and the trunk at the same time - the car chimes three times softly if you try to do that IIRC, you should be able to hear it if you're close to it.
