corsa sport install question
Old Apr 30, 2011 | 12:18 PM
xgto's Avatar
xgto
Default corsa sport install question
Found a super clean corsa sport on craigslist it will be here Monday.
on my 05 mn6 can I get off the stock exhaust without taking down the mid h pipe ?
Old Apr 30, 2011 | 01:32 PM
Mike Smith's Avatar
Mike Smith
I'm not sure, but here is a good video on removing the stock exhaust on a 2005, and replacing it with a Corsa Sport: http://www.youtube.com/watch?v=DJaJjUoUOms
Old Apr 30, 2011 | 01:49 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Here's a link to Corsa's official installation instructions:
http://www.corsaperf.com/media/pdf/INS5036.pdf
On mn6 cars it looks like all you have to do is unbolt the spring hangers to give you a bit more swing, unless you feel like cutting.
I've had to reinstall mine a few times now and I'll just say it is really pretty easy. One thing to be sure of though is to make sure the over the axle pipe is clear of the frame (by either pulling it back or pushing it forward in the H pipe) so that the curve in the over axle pipe does not hit on turns.
Old Apr 30, 2011 | 03:01 PM
djbrun's Avatar
djbrun
Dropping the h-pipe doesn't take long and sure makes it easy.
DJ
Old May 1, 2011 | 03:52 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
If you're buying a used Corsa system, they recommend you use new clamps.
And you should re-torque them after a couple heat/cool cycles.
Great sounding exhaust system, good luck.
Old May 1, 2011 | 07:51 AM
xgto's Avatar
xgto
what size do I need to buy for the mufflers and also the connection to the mid pipe, acuseal ?
Old May 1, 2011 | 07:53 AM
breecher_7's Avatar
breecher_7
Its easier to put in if you drop the mid pipe, mid pipe is only held in place by 6 bolts and takes about 5 mins to remove. If you have a friend to help you this install shouldnt take an hour. Getting the tips aligned will be the biggest pain in the ***.
Old May 1, 2011 | 07:54 AM
breecher_7's Avatar
breecher_7
You dont need new clamps or seals, it will be fine.
Old May 1, 2011 | 11:29 AM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
You don't need new clamps. I couldn't get it out with out dropping the H-Pipe. Its easy to get out anyway.
Old May 1, 2011 | 05:53 PM
Mike Campbell's Avatar
Mike Campbell
Drop the X pipe...it makes the whole job easier.
Old May 2, 2011 | 09:30 AM
Bandit1's Avatar
Bandit1
Agree. You will be speaking a foreign language and really hating yourself if you don't drop the mid-pipe (H or X). It doesn't take that long, easiest part of the job, and makes the removal and install so much easier. In addition, you will need the mid-pipe loosened during install to assist you in aligning the over the axle pipes and mufflers/tips.
To corsa sport install question
