$874 for a waterpump install
I ended up purchasing a new (not rebuilt) pump from Autozone for about $130 plus coolant and a few little things. Replaced it myself, total out of pocket was less than $160. Took me a few hours, could do it again in less than an hour.
Hope that helps.
Last time I did a W/P on a 06 C6 I charged 1/2 that and that included the pump. If you're willing to tackle the job yourself do a search for a write-up. If you can't find one let me know and I'll create one for you. Should take you a few hrs give or take. If not, search around for better quotes. Just be careful of who does the work. Sometimes you get for what you pay for.
Took me a few hrs. I'd say 2 hrs start to finish for water pump only.
I paid $209 for my LS7 pump from Scoggin Dickey.
should be 2 hrs shop time + pump. I filtred my antifreeze and reused it ( it wasn't that old)
A/C belt IS seperate from the serp belt. Just wash them both in warm soapy water, let dry and reinstall. Fact is, unless they look shreaded or cracked, re-use them. Wifes L92 Denali has 87K on it and that serp belt looks fine.
oh yeah....look for another dealer to service your car. those guys are doubling the corvette tax on you
Mine is a DD, so could not afford downtime and the reason I inquired about others doing it for me. After I finished I wondered why they charge so much given how easy it was to replace. I'd tackle it again without a doubt.
Unfortunately almost all my coolant went down the street to the ocean. Not by choice, what happened is I parked, turned off the engine and the old pump just blew the old coolant out while under pressure. I would never do that intentionally, if I had the choice I would have captured the old coolant. Not sure where to take old coolant if I had captured it though. Oil I know where to take for proper disposal, other fluids not so sure.
And nobody ever thought about going to a dealership to get it replaced.
Times ... they are a changing
BTW, my pump had a "made in Canada" sticker on it. welcome to the 21st century. Capitalism has no international boundries.
Here is how it works...
1) up on jack stands
2) drain coolant
3) disconnect TB and inlet assembly
4) disconnect coolant hoses
5) take off serp belt
6) take off (6) fasteners
7) remove pump
8) remove tensioner off pump
8) Install new H2O assembly
9) 1st pass H2O pump belts ..11 ft/lbs
10) second pass ..15 ft lbs
11) re-assemble in reverse order.
I know we are becoming a nation of getting paid for "what we know" , but a little common sense and trial and error can save you a ton of $$$$$.
Additonally, you've just helped your local highschoolers learn a valuable tech trade. Maybe we can be an industrious country once again..
another thought: ( just like racing or HPDE your C6Z) If you can't afford to repair it/replace it .....you can't afford it.
