Lifters
Old May 4, 2011 | 08:28 PM
C7&7's Avatar
C7&7
Default Lifters
I am about to install new heads, should I go ahead and install new lifters while I am in there? Car is an '05 with 38K miles.
Old May 4, 2011 | 08:43 PM
HuskerBullet's Avatar
HuskerBullet
IMO, you can if you feel insecure, but not necessary. However, if you are replacing the heads, then you might as well replace the 1.7:1 ratio rocker arms with something like Comp Cams 1.85:1 ratios kit....it's like installing a mild cam giving you a valve lift from .519 up to about .565 which I think is worth it if you plan on never changing the cam to something larger like .588 or above .600. And, If you do replace the rockers, then absolutely replace the push rods with after-market ones (chrome-moly). Fun stuff, good luck!
Old May 4, 2011 | 10:22 PM
breecher_7's Avatar
breecher_7
For $120, i would...
Old May 12, 2011 | 09:54 PM
C7&7's Avatar
C7&7
Default LS7 Lifters
About to do a head swap and was curious if LS7 lifters work in a LS2.
Old May 12, 2011 | 09:59 PM
breecher_7's Avatar
breecher_7
yes
Old May 12, 2011 | 10:01 PM
C7&7's Avatar
C7&7
Suuuuuweeet
To Lifters
