G.s. Crankshafts
Old May 5, 2011 | 10:29 AM
jack5hd's Avatar
jack5hd
Default G.s. Crankshafts
Does the dry sump version motor on g.s. Also have abetter crank?.i know it is longer but is it a stronger crank then in tha automatic versions? Thanks j.k.
Old May 5, 2011 | 10:40 AM
RicK T's Avatar
RicK T
Well, the dry sump engines have a forged crank vs. cast. Better? Basically yes. Does it mean anything if you aren't racing or adding HP mods?
Old May 14, 2011 | 01:50 PM
jack5hd's Avatar
jack5hd
How much more h.p. Mods can the stock crank take before you need to beef it up also?j.k.
Old May 14, 2011 | 03:08 PM
JoesC5's Avatar
JoesC5
Same crank as is used in the 638 HP LS9, except for the number of bolts that attach the flywheel.
Old May 14, 2011 | 04:25 PM
ls3gotcha's Avatar
ls3gotcha
stock crank will hold quite a bit everyone has their opinions but i wouldnt hesitate to run 800 horse on one
Old May 14, 2011 | 04:27 PM
Motorhead-47's Avatar
Motorhead-47
The LS3 crank typically IS NOT the weak link
Old May 14, 2011 | 04:50 PM
Stang's Bane's Avatar
Stang's Bane
Also it is not forged.
Old May 14, 2011 | 05:14 PM
smurfkiller's Avatar
smurfkiller
your gonna run into other probs before the crank becomes the weak link
Old May 15, 2011 | 10:43 AM
jack5hd's Avatar
jack5hd
i thought the crank was forged on the manual transmission versions of g.s...........if i bump the power up 100 or 150 h.p. will it still be fairly reliable.can the differential handle more then stock?thanks j.k.
Old May 15, 2011 | 10:54 AM
Motorhead-47
The weak link is normally the pistons when you push the engines hard. 100-150 additional rwhp can be very reliable. Reliability and longevity very much depend on how you drive your car though.
Old May 15, 2011 | 01:40 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Last month's Hot Rod magazine had an list of what breaks at what power level on the LS3. It said the cranks are good to about 900 flywheel HP. Just about everything else will go before the crank.
To G.s. Crankshafts
