Throttle pedal adjustment stop?
My car has always had a slight movement in the pedal before engine response.
I also looked in my '06 and '10 Service Manuals and there's absolutely no mention of anything that can be adjusted on the pedal.
I'm not sure what you're looking at, but it might just be the screw that holds the APP sensor (Accelerator Pedal Position sensor - there are actually 2 of them: APP1 and APP2) to the pedal.
So.....I don't believe that there is anything that you can adjust, and if there is I don't recommend messing with it. If you need to adjust some throttle parameter like idle, you need to tune the ECM.
The stock throttle response is really crappy - I've had a lot of lag on all three of the C6's I've owned.
On my '05 Coupe I tuned it with a Predator and the improvement in throttle response was one of the best things from the tune.
For my '06 Z06 I used LS1Edit to tune the car, and again the quicker throttle response was one of the best features of the tune.
With a tune, you can adjust the throttle tip-in to make the throttle come on a lot quicker. And of course a tune can improve power on even a stock engine - I think the forum wisdom is probably 10 or 15 hp increase from a tune even without any other mods.
However, because a tune might possibly void the warranty, I haven't yet tuned my '09 ZR1. But, the throttle response was really lousy, and I really wanted to improve it.
I got a SprintBooster unit and it really perked up the throttle to what I wanted. It's not cheap, but cheaper than getting the car tuned, but you don't get the other benefits of a tune, but you won't possibly void the warranty either.
Bob
Removing the entire pedal assembly makes it easy, but if you know how to push the pin out with a C-clamp and socket then it's very easy doing the job without removing the pedal assembly.
Either way, the upgrade to a nice aluminum pedal is worth the few minutes it takes to install it:
Mine in the picture above is the EE heel-n-toe pedal - it's wider to allow better heel-n-toeing when downshifting.
I've got their matching aluminum dead pedal.
Bob
Fast starts are no problem , like you say ; stab the pedal.
If this screw doesn't function as an adjustment ; I will figure out some kind of shim to fix my problem.
Yep - I went with the "old school" push-button switch for my 2009.
For my 2006 I have the wireless remote. It has the early visor and the buttons are very easy to program - and I programmed the visor buttons to operate the valves.
The new visor is harder to program. I think there's a wireless valve controller that will allow you to program the newer visor buttons, but I went with the push-button, and I really like it!!
Bob
